All of my Aeotec Z-Wave Smart Energy switches Model DSC06106-ZWUS are not working via app or alexa. The app just says “Turning On” or “Turning Off”. Alexa, just says OK. However, in the IDE they show up as online, and they do update their switch status. If I turn one on manually, it shows as on, turn it off manually, it shows as off.
I have tried restarting the Hub (v2). I am still on the classic app and I have not yet received any notice to migrate.
Any ideas?
tgauchat
2
I’m sorry. I am not an advanced user. When I look at the Live logging tab there is nothing significant there. if you mean event list for the device(s) it shows things happening. Power, Energy, switch position (assuming it is from me pressing the manual switch)
tgauchat
4
If there’s nothing unusual in Live Logging but “normal” events are being shown, then SmartThings Support can possibly assist you. They have access to more detailed internal logs.
Actually, just tried to hit the device on the app, and got this in live logging: same thing on all my aeotec switches. i get one each time i try to use the device from the app.
tgauchat
8
What happens when you click on the long-number (the device ID) to the LEFT of that message in Live Logging?
That will confirm which Device Instance this message is coming from.
You can then contact Developer of the Device Type Handler with that exact error message. They can diagnose line 295. Are you using a Custom Device Type Handler (i.e., pasted into the IDE or linked via GitHub)? If not, then SmartThings is the Developer.
clicking on that long id string just makes the other entries go away, nothing new, other than the device name appear up top, next to ALL. It is a smartthings handler. I have never pasted anything. Very basic here.
tgauchat
10
That’s good. It confirms exactly which device that error is from.
SmartThings Support ought to be able to help diagnose, since the current source code may not be openly published for anyone in the Community to attempt to diagnose.
All my Aeotec stopped working sometime after 8am as well. All 6 of them. ST must have triggered something for this to occur to multiple people.
tgauchat
14
That’s certainly possible: I believe that “Tuesday” is rollout day across the platform; though I thought that all “firmware updates” were pre-announced… Not every platform change is announced; So it makes it impossible for us folks out here to figure out what happened(s).
There’s a slight chance the just doing a full hub power cycle (i.e., remove batteries and power for 15 minutes), could also force the failing devices to reset and reconnect in the correct state, without a full-remove.
I have mine in lots of routines if anyone figures out a way besides deleting and re adding. This is actually the first problem I have EVER had with my V1 hub and I mean EVER.
Also having this problem as described in the OP. The one switch that continued to work was the one where i was running a custom device handler. Aeon Labs Smart Energy Switch. You should be able to find it pretty easily. Switching to that device type from Z-wave Metering Switch fixed all the others. I simply dont have the patience to add/remove all of them and local processing be damned.
