Here the Drivers log
2023-07-07T23:05:01.377349740+00:00 TRACE Z-Wave Switch  Received event with handler capability
2023-07-07T23:05:01.399433074+00:00 TRACE Z-Wave Switch  Z-Wave command(42273673) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2023-07-07T23:05:01.406124740+00:00 INFO Z-Wave Switch  <ZwaveChildDevice: 282bdfae-02f3-4033-ac75-b0c5691271fd [9d761dd4-48c4-458e-8446-b1deccc18996][01] (Z-Wave Device Multichannel 1)> received command: {“args”:{},“positional_args”:{},“capability”:“switch”,“component”:“main”,“command”:“on”}
2023-07-07T23:05:01.407630407+00:00 TRACE Z-Wave Switch  Found CapabilityCommandDispatcher handler in zwave_switch
2023-07-07T23:05:01.409014074+00:00 TRACE Z-Wave Switch  SWITCH_MULTILEVEL supported.
2023-07-07T23:05:01.410447407+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> sending Z-Wave command: {args={duration=“default”, value=“ON_ENABLE”}, cmd_class=“SWITCH_MULTILEVEL”, cmd_id=“SET”, dst_channels={1}, encap=“AUTO”, payload=“\xFF\xFF”, src_channel=0, version=2}
2023-07-07T23:05:01.440717740+00:00 TRACE Z-Wave Switch  Z-Wave command(42273673) transmit status: TRANSMIT_COMPLETE_OK
2023-07-07T23:05:01.456604074+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel 1 device thread event handled
2023-07-07T23:05:01.457432074+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel 1 device thread event handled
2023-07-07T23:05:06.475876074+00:00 TRACE Z-Wave Switch  Z-Wave command(0dd2d3fa) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2023-07-07T23:05:06.477381407+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> sending Z-Wave command: {args={}, cmd_class=“SWITCH_MULTILEVEL”, cmd_id=“GET”, dst_channels={1}, encap=“AUTO”, payload=“”, src_channel=0, version=1}
2023-07-07T23:05:06.484774407+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel 1 device thread event handled
2023-07-07T23:05:06.569841741+00:00 TRACE Z-Wave Switch  Z-Wave command(0dd2d3fa) transmit status: TRANSMIT_COMPLETE_OK
2023-07-07T23:05:14.896618408+00:00 TRACE Z-Wave Switch  Received event with handler capability
2023-07-07T23:05:14.935899075+00:00 TRACE Z-Wave Switch  Z-Wave command(5d46192d) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2023-07-07T23:05:14.955847075+00:00 INFO Z-Wave Switch  <ZwaveChildDevice: c0176bff-f7cb-48ed-8bf5-98da0a81cfd1 [9d761dd4-48c4-458e-8446-b1deccc18996][02] (Z-Wave Device Multichannel 2)> received command: {“args”:{},“positional_args”:{},“capability”:“switch”,“component”:“main”,“command”:“on”}
2023-07-07T23:05:14.957643742+00:00 TRACE Z-Wave Switch  Found CapabilityCommandDispatcher handler in zwave_switch
2023-07-07T23:05:14.958837408+00:00 TRACE Z-Wave Switch  SWITCH_MULTILEVEL supported.
2023-07-07T23:05:14.959999408+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> sending Z-Wave command: {args={duration=“default”, value=“ON_ENABLE”}, cmd_class=“SWITCH_MULTILEVEL”, cmd_id=“SET”, dst_channels={2}, encap=“AUTO”, payload=“\xFF\xFF”, src_channel=0, version=2}
2023-07-07T23:05:14.970233408+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel 2 device thread event handled
2023-07-07T23:05:14.980251075+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel 2 device thread event handled
2023-07-07T23:05:15.069822408+00:00 TRACE Z-Wave Switch  Z-Wave command(5d46192d) transmit status: TRANSMIT_COMPLETE_OK
2023-07-07T23:05:19.971853076+00:00 TRACE Z-Wave Switch  Z-Wave command(36cb6ff7) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2023-07-07T23:05:19.980211409+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> sending Z-Wave command: {args={}, cmd_class=“SWITCH_MULTILEVEL”, cmd_id=“GET”, dst_channels={2}, encap=“AUTO”, payload=“”, src_channel=0, version=1}
2023-07-07T23:05:19.981952076+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel 2 device thread event handled
2023-07-07T23:05:20.069733076+00:00 TRACE Z-Wave Switch  Z-Wave command(36cb6ff7) transmit status: TRANSMIT_COMPLETE_OK
2023-07-07T23:05:42.040974745+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:05:42.042415412+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={key_attributes=“KEY_RELEASED”, scene_number=2, sequence_number=18, slow_refresh=false}, cmd_class=“CENTRAL_SCENE”, cmd_id=“NOTIFICATION”, dst_channels={}, encap=“NONE”, payload=“\x12\x01\x02”, src_channel=0, version=3}
2023-07-07T23:05:42.055867078+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.058988078+00:00 WARN Z-Wave Switch  Attempted to generate event for 9d761dd4-48c4-458e-8446-b1deccc18996.main but it does not support capability Button
2023-07-07T23:05:42.067858078+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:05:42.073554078+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:05:42.077291412+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={value=255}, cmd_class=“BASIC”, cmd_id=“REPORT”, dst_channels={2}, encap=“NONE”, payload=“\xFF”, src_channel=2, version=1}
2023-07-07T23:05:42.094648745+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.105259412+00:00 INFO Z-Wave Switch  <ZwaveChildDevice: c0176bff-f7cb-48ed-8bf5-98da0a81cfd1 [9d761dd4-48c4-458e-8446-b1deccc18996][02] (Z-Wave Device Multichannel 2)> emitting event: {“component_id”:“main”,“state”:{“value”:“on”},“attribute_id”:“switch”,“capability_id”:“switch”}
2023-07-07T23:05:42.119279745+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.139301745+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Switch Level
2023-07-07T23:05:42.140617078+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.141814745+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.153473078+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Contact Sensor
2023-07-07T23:05:42.168041412+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.169278412+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Motion Sensor
2023-07-07T23:05:42.171420078+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:42.179210078+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Water Sensor
2023-07-07T23:05:42.182788412+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:05:51.146992413+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:05:51.148413413+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={key_attributes=“KEY_RELEASED”, scene_number=2, sequence_number=19, slow_refresh=false}, cmd_class=“CENTRAL_SCENE”, cmd_id=“NOTIFICATION”, dst_channels={}, encap=“NONE”, payload=“\x13\x01\x02”, src_channel=0, version=3}
2023-07-07T23:05:51.169593079+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:05:51.173183413+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={value=0}, cmd_class=“BASIC”, cmd_id=“REPORT”, dst_channels={2}, encap=“NONE”, payload=“\x00”, src_channel=2, version=1}
2023-07-07T23:05:51.184614413+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.185412413+00:00 WARN Z-Wave Switch  Attempted to generate event for 9d761dd4-48c4-458e-8446-b1deccc18996.main but it does not support capability Button
2023-07-07T23:05:51.199218079+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:05:51.206003746+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.216789079+00:00 INFO Z-Wave Switch  <ZwaveChildDevice: c0176bff-f7cb-48ed-8bf5-98da0a81cfd1 [9d761dd4-48c4-458e-8446-b1deccc18996][02] (Z-Wave Device Multichannel 2)> emitting event: {“component_id”:“main”,“state”:{“value”:“off”},“attribute_id”:“switch”,“capability_id”:“switch”}
2023-07-07T23:05:51.230474413+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.244726079+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.246618413+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.252761413+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Contact Sensor
2023-07-07T23:05:51.254246079+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.265611413+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Motion Sensor
2023-07-07T23:05:51.270075079+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:51.278142746+00:00 WARN Z-Wave Switch  Attempted to generate event for c0176bff-f7cb-48ed-8bf5-98da0a81cfd1.main but it does not support capability Water Sensor
2023-07-07T23:05:51.281804413+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:05:56.221698747+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:05:56.225374413+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={key_attributes=“KEY_RELEASED”, scene_number=1, sequence_number=20, slow_refresh=false}, cmd_class=“CENTRAL_SCENE”, cmd_id=“NOTIFICATION”, dst_channels={}, encap=“NONE”, payload=“\x14\x01\x01”, src_channel=0, version=3}
2023-07-07T23:05:56.246934413+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:05:56.250247747+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={value=255}, cmd_class=“BASIC”, cmd_id=“REPORT”, dst_channels={1}, encap=“NONE”, payload=“\xFF”, src_channel=1, version=1}
2023-07-07T23:05:56.257284747+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.258098080+00:00 WARN Z-Wave Switch  Attempted to generate event for 9d761dd4-48c4-458e-8446-b1deccc18996.main but it does not support capability Button
2023-07-07T23:05:56.262680413+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:05:56.278000080+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.289243413+00:00 INFO Z-Wave Switch  <ZwaveChildDevice: 282bdfae-02f3-4033-ac75-b0c5691271fd [9d761dd4-48c4-458e-8446-b1deccc18996][01] (Z-Wave Device Multichannel 1)> emitting event: {“component_id”:“main”,“state”:{“value”:“on”},“attribute_id”:“switch”,“capability_id”:“switch”}
2023-07-07T23:05:56.300773080+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.313726080+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Switch Level
2023-07-07T23:05:56.326997080+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.328611080+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.333980413+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Contact Sensor
2023-07-07T23:05:56.335293747+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.346830747+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Motion Sensor
2023-07-07T23:05:56.358014413+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:05:56.358844413+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Water Sensor
2023-07-07T23:05:56.361233080+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:06:03.443185414+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:06:03.445051081+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={key_attributes=“KEY_RELEASED”, scene_number=1, sequence_number=21, slow_refresh=false}, cmd_class=“CENTRAL_SCENE”, cmd_id=“NOTIFICATION”, dst_channels={}, encap=“NONE”, payload=“\x15\x01\x01”, src_channel=0, version=3}
2023-07-07T23:06:03.469667081+00:00 TRACE Z-Wave Switch  Received event with handler unnamed
2023-07-07T23:06:03.473368081+00:00 INFO Z-Wave Switch  <ZwaveDevice: 9d761dd4-48c4-458e-8446-b1deccc18996 [12] (Switch)> received Z-Wave command: {args={value=0}, cmd_class=“BASIC”, cmd_id=“REPORT”, dst_channels={1}, encap=“NONE”, payload=“\x00”, src_channel=1, version=1}
2023-07-07T23:06:03.480532081+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.481371748+00:00 WARN Z-Wave Switch  Attempted to generate event for 9d761dd4-48c4-458e-8446-b1deccc18996.main but it does not support capability Button
2023-07-07T23:06:03.487693081+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
2023-07-07T23:06:03.502550748+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.528812414+00:00 INFO Z-Wave Switch  <ZwaveChildDevice: 282bdfae-02f3-4033-ac75-b0c5691271fd [9d761dd4-48c4-458e-8446-b1deccc18996][01] (Z-Wave Device Multichannel 1)> emitting event: {“component_id”:“main”,“state”:{“value”:“off”},“attribute_id”:“switch”,“capability_id”:“switch”}
2023-07-07T23:06:03.531009414+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.536049748+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.538010414+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.547064748+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Contact Sensor
2023-07-07T23:06:03.557027081+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.561156748+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Motion Sensor
2023-07-07T23:06:03.564710414+00:00 TRACE Z-Wave Switch  Found ZwaveDispatcher handler in zwave_switch
2023-07-07T23:06:03.571656748+00:00 WARN Z-Wave Switch  Attempted to generate event for 282bdfae-02f3-4033-ac75-b0c5691271fd.main but it does not support capability Water Sensor
2023-07-07T23:06:03.577100748+00:00 DEBUG Z-Wave Switch  Z-Wave Device Multichannel device thread event handled
