How do you exclude from a hub you are not connected to?
As I understand it, Zwave controllers (our hubs) can broadcast for devices to exclude. If a deviceâs exclusion process is activated while ANY controller is broadcasting exclusion, the device will âforgetâ itâs previous association with any other controller.
Iâm not sure I explained that well, but essentially the V2 hub can be put into exclusion mode (go to Zwave utilities by clicking on the hub in the locations menu), and your devices will forget their old network when excluded. Worked great for me.
This is why the Minimotes work well, because they are portable controllers. You can be sure you are activating exclusion while you are standing next to the device you are going to wipe and reconnect.
Mine unpaired from my v1 at first attempt, but I did have issues with the zcombo smoke detectors. Then the best approach was both the reset at the device itself (the zcombo in this case) and also the generic zwave exclusion from the ST app. That eventually cleared things for me, might work for the zwave meter device also.
I excluded the Switch with the new V2 hub and am now able to add it. I removed the switch from the V1 hub and then removed the V1 hub from my account. After that I unplugged the V1 hub. The switch auto identifies as an Aeon outlet. It doesnât actually work that way though. An âunexpected errorâ occurs when I try to complete Connect New Device. It does show up in the device list. Iâve tried editing the device to use the elasticdev : Aeon Labs Smart Energy Switch device type. I donât get any errors when I do this but the switch still doesnât work. Also, if I try to rename the device in the app I get the âunexpected errorâ again. Is there any way to pair using the Aeon Labs Smart Energy Switch device type? I canât find it in the device list and have to use the generic Connect New Device button in the app.
After reading the engineering spec for the switch on The Smartest House website I found a reset function. Holding the button for more than 20 seconds resets the device to factory defaults.
After resetting the device I again paired it to the new V2 hub. It again identified as an Aeon Outlet but this time the setup completed without errors. As a bonus the switch now works without the custom driver. The default driver lacks some of the cool monitoring features but does support basic on/off functionality.
I got 3 of these cheap on Amazon 29 bucks. But the would not work reliably âŚthey would only turn in or off maybe 40 percent of the time⌠maybe why they were so cheap⌠the either 3 brands of switches including the newer aeon switch v6 work every time.
Hi there, just added this device type and I donât get any response when I hit the CONFIGURE button. Can you take a look at whatâs going on?
Is this something different that described in this post above in this thread?
Gread device handler. I just upgraded to it, so I could disable the switch. One thing I miss from the other device type is seeing the current W value. Is this something that can be added?
Thanks,
YES!
I must have dropped that in an update. Just updated the source code in GitHub to put it back.
Awesome. I will sync my code when I get home this weekend. BTW great update.
Hi James,
I have a new v2 smartthings hub and am just started with home automation. I have 2 of these aeon labs smart energy switches in my network and thatâs it. The switches were working fine when I was there last week, I turned them on and off many times successfully. However, now that I am 700 miles away they have stopped working. I know this because when I turn them off, the energy continues to be updated. I have added your code (thanks very much!) to one of my devices but it still doesnât seem to work.
I have tried repairing my zwave network (I get a failure for the switches in the log for some reason)
I have tried rebooting my hub.
Do you have any suggestions on what I might do to get it working?
One more tidbit of info is that on tuesday I discovered it not working (energy resets/refreshes not taking effect/off not taking affect). However, on wednesday it worked just fine for a few hours, then yesterday it stopped working again.
Any suggestions would be very much appreciated!!!
All the best!
Brian Hiltscher
I was having real trouble getting this to do any reporting without manually refreshing. Finally, I removed the device, did a factory reset (held the button for 20 seconds as someone posted above; not sure if that actually did anything), and re-added it and now itâs reporting.
I also changed the reportInterval to be in seconds instead of minutes. I donât plan to leave that at a low number because it might overload the z-wave network, but itâs very useful for testing to set it to 1 second.
Everything seems to be working well now.
Sorry I missed this message.
Have you turned on the debug logging? If you did that and sent me the logs from the IDE, that would help me diagnose the problem.
James
Hi James,
Thanks for responding to my post!
Actually I hadnât tried the logging, however Iâve just turned it on. Below is the current output.
Would you like me to leave it on for a certain amount of time, or attempt to control the device/hub?
Thanks very much!
Brian Hiltscher
919-368-1753
66b005bb-2981-4300-bfd1-953b5ef4568f 11:25:08 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:23:36 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:23:04 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:22:57 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:22:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:22:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
11:22:25 AM EST: info Waiting on eventsâŚ
11:22:25 AM EST: info For past logs for individual things go to the My Devices section, find the device and click on the Events link on the device information page.
11:22:25 AM EST: info This console provides live logging of your SmartThings.
some more events, is there a better way to send them to you?
66b005bb-2981-4300-bfd1-953b5ef4568f 12:28:20 PM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:28:14 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:27:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:27:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:26:36 PM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:25:21 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:23:19 PM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:23:12 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:22:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:22:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:21:21 PM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:20:20 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:18:18 PM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:18:11 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:17:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:17:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:16:06 PM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:15:19 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:13:16 PM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:13:10 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:12:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:12:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:11:27 PM EST: debug hubActiveHandler(devicetype:04, mac:CC6DA01FC1CD, networkAddress:C0A8018D, deviceAddress:1F7C, stringCount:04, ssdpPath:/, ssdpUSN:uuid:roku:ecp:11C1A0019050, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:10:51 PM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:10:18 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:08:15 PM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:08:08 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:07:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:07:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:05:36 PM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:05:16 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:03:14 PM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:03:07 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:02:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:02:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:00:21 PM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 12:00:15 PM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:58:13 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:58:06 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:57:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:57:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:55:14 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:55:06 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:53:11 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:53:05 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:52:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:51:28 AM EST: debug hubActiveHandler(devicetype:04, mac:CC6DA01FC1CD, networkAddress:C0A8018D, deviceAddress:1F7C, stringCount:04, ssdpPath:/, ssdpUSN:uuid:roku:ecp:11C1A0019050, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:50:12 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:49:51 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:48:10 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:48:03 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:47:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:47:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:45:11 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:44:36 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:43:09 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:43:02 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:42:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:42:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:40:10 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:39:21 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:38:07 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:38:01 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:37:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:37:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:35:09 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:34:06 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:33:06 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:33:00 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:32:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:32:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:31:29 AM EST: debug hubActiveHandler(devicetype:04, mac:CC6DA01FC1CD, networkAddress:C0A8018D, deviceAddress:1F7C, stringCount:04, ssdpPath:/, ssdpUSN:uuid:roku:ecp:11C1A0019050, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:30:09 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E9344, networkAddress:C0A80165, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57950::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:28:51 AM EST: debug hubActiveHandler(devicetype:04, mac:501AC5098BA6, networkAddress:C0A80101, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:060b7353-fca6-4070-85f4-1fbfb9add62c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:28:05 AM EST: debug hubActiveHandler(devicetype:04, mac:B010413C3143, networkAddress:C0A80166, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-fcf15244181d::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:27:58 AM EST: debug hubActiveHandler(devicetype:04, mac:5435302E720D, networkAddress:C0A80164, deviceAddress:C419, stringCount:04, ssdpPath:/dial.xml, ssdpUSN:uuid:00000004-0000-1010-8000-d8d43cd57a2c::upnp:rootdevice, ssdpTerm:, ssdpNTS:ssdp:alive)
66b005bb-2981-4300-bfd1-953b5ef4568f 11:27:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 11:27:47 AM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
Sorry for the inexact language.
If you could provide the logging for the devices in question that would be great. This is the logging for the entire hub, most of which is too verbose for me to look at.
You could follow the hint in the quote above or filter the log just to the device, that would really help.
James
Hey James,
Sorry about that, I have filtered out all messages save those to the device, here you goâŚ
66b005bb-2981-4300-bfd1-953b5ef4568f 3:27:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 19 01 2C 00 00 00 2A )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:27:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 2A 01 2C 00 00 00 2A )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:27:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 2A 01 2C 00 00 00 2A )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:22:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 13 01 2C 00 00 00 29 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:22:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 2A 01 2C 00 00 00 29 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:22:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 2A 01 2C 00 00 00 29 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:17:51 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 17 01 2C 00 00 00 28 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:17:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 17 01 2C 00 00 00 28 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:17:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 29 01 2C 00 00 00 28 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:12:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 01 01 2C 00 00 00 28 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:12:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 28 01 2C 00 00 00 28 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:07:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 05 01 2C 00 00 00 27 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:07:49 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 28 01 2C 00 00 00 27 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:07:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 28 01 2C 00 00 00 27 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:02:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1F 07 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 3:02:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 27 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:57:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 1E F5 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:57:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:52:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:52:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:47:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:47:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:42:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:42:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:37:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:37:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:32:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:32:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:22:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:22:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:17:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:17:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:12:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:12:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:07:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:07:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:02:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 2:02:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:57:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:57:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:52:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:52:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:47:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:47:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:42:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:42:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:37:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:37:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:32:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:32:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:27:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:27:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:22:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:22:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:17:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:17:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:12:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:12:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:07:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:07:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:02:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 1:02:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:57:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:57:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:52:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:52:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:47:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:47:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:42:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:42:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:37:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:37:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:32:48 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 74 00 00 00 00 01 2C 00 00 00 26 )
66b005bb-2981-4300-bfd1-953b5ef4568f 12:32:47 PM EST: debug hubActiveHandler(zw device: 04, command: 3202, payload: 21 64 00 00 00 26 01 2C 00 00 00 26 )
@jpansarasa, I like the Device Handler.
I have a request. Is it possible to include the reset date in the âReset KWHâ tile. It would be nice to know the date of the last reset so the power consumption of a device can be understood.
Or maybe add another tile as shown in this Device Handler:
Hi @damohabir, are you looking for something like this?
https://raw.githubusercontent.com/constjs/SmartThings-Devices/master/aeon_smart_switch.device.groovy
Thatâs what I created for myself a while back, but I just updated it to also include the ability to disable the switch and debug logging like what @jpansarasaâs device handler does. With my device handler, making configuration changes needs to be done in the code, and power events are always sent to the activity log. I may go back and change my device handler a little later after I finish another project.
The image you see is from v2.0.7 of the Android app. Please be aware that v2.0.8 screws up the main tile format, and those 2 lines of text will become more centered, and youâll lose the second line, depending on what size font your phone is using.
