Aeon Labs DSC06106-ZWUS - which device type to use?
Which device type seems to be the most reliable? I know its subjective, but I’m looking for one that reports the Watts being used. Ideally user configurable but that’s not too hard to change in the code. Is there a list that shows all the devices types (with descriptions) that work for this switch?
Here’s the one I use; works very well:
[code]/*
  • Aeon Smart Energy Switch v2 (for DSC06106)
  • Copyright 2015 Mr. Lucky
  • based on v1 code by James P (‘elasticdev’)
  • Revision History
  • 2015-10-09: Version: 2.0.1 -Mr. Lucky
  • Defined ‘event’ as empty (vs. “null”)
  • 2015-09-10: Version: 2.0.0 -Mr. Lucky
  • Converted tiles to ST v2 style
  • 2015-01-27: Version: 1.2.0
  • Added preference to turn on/off displaying of power events in the activity log
  • 2015-01-24: Version: 1.1.0
  • Added updated() method
  • Moved to boolean values in state rather than call toBoolean() on preference
  • Cleaner logic for on() and off()
  • 2015-01-21: Version: 1.0.0
  • Initial Revision
  • Developer’s Notes
  • Raw Description 0 0 0x1001 0 0 0 a 0x25 0x31 0x32 0x27 0x70 0x85 0x72 0x86 0xEF 0x82
  • Z-Wave Supported Command Classes:
  • Code Name Version
  • 0x25 COMMAND_CLASS_SWITCH_BINARY V1
  • 0x31 COMMAND_CLASS_SENSOR_MULTILEVEL V5
  • 0x32 COMMAND_CLASS_METER V3
  • 0x70 COMMAND_CLASS_CONFIGURATION V1
  • ---- ---- Supported but unimplemented ----- –
  • 0x27 COMMAND_CLASS_SWITCH_ALL V1
  • 0x85 COMMAND_CLASS_ASSOCIATION V2
  • 0x72 COMMAND_CLASS_MANUFACTURER_SPECIFIC V2
  • 0x86 COMMAND_CLASS_VERSION V2
  • 0xEF COMMAND_CLASS_MARK V1
  • 0x82 COMMAND_CLASS_HAIL V1
    metadata {
    definition (name: “Smart Energy Switch v2”, namespace: “HDFLucky”, author: “Mr. Lucky”) {
    capability "Actuator"
    capability "Configuration"
    capability "Energy Meter"
    capability "Polling"
    capability "Power Meter"
    capability "Refresh"
    capability "Sensor"
    capability “Switch”
    command “reset”
    fingerprint deviceId: “0x1001”, inClusters: “0x25, 0x31, 0x32, 0x27, 0x70, 0x85, 0x72, 0x86, 0xEF, 0x82”
    // simulator metadata
    simulator {
    status “on”: "command: 2003, payload: FF"
    status “off”: “command: 2003, payload: 00”
    for (int i = 0; i <= 10000; i += 1000) {
    status “power ${i} W”:
    new physicalgraph.zwave.Zwave().meterV1.meterReport(scaledMeterValue: i, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
    for (int i = 0; i <= 100; i += 10) {
    status “energy ${i} kWh”:
    new physicalgraph.zwave.Zwave().meterV1.meterReport(scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
    // reply messages
    reply “2001FF,delay 100,2502”: "command: 2503, payload: FF"
    reply “200100,delay 100,2502”: “command: 2503, payload: 00”
    // tile definitions
    tiles(scale: 2) {
    multiAttributeTile(name:“switch”, type: “lighting”, width: 6, height: 4, canChangeIcon: true) {
    tileAttribute (“device.switch”, key: “PRIMARY_CONTROL”) {
    attributeState “on”, label: ‘${name}’, action: “switch.off”, icon: “st.switches.switch.on”, backgroundColor: "#79b821"
    attributeState “off”, label: ‘${name}’, action: “switch.on”, icon: “st.switches.switch.off”, backgroundColor: “#ffffff”
    tileAttribute (“device.power”, key: “SECONDARY_CONTROL”) {
    attributeState “statusText”, label:‘Current power draw: ${currentValue} W’
    valueTile(“energy”, “device.energy”, width: 2, height: 2) {
    state “default”, label:’${currentValue} kWh’
    standardTile(“refresh”, “device.power”, decoration: “flat”, width: 2, height: 2) {
    state “default”, label:’ ', action:“refresh.refresh”, icon:“st.secondary.refresh”
    standardTile(“configure”, “device.power”, decoration: “flat”, width: 2, height: 2) {
    state “configure”, label:’ ', action:“configuration.configure”, icon:“st.secondary.configure”
    standardTile(“reset”, “device.energy”, decoration: “flat”, width: 2, height: 2) {
    state “default”, label:’ ', action:“reset”, icon:‘https://dl.dropboxusercontent.com/u/52901840/reset_kWh@2x.png’
    main ([“switch”, “energy”])
    details([“switch”, “power”, “refresh”, “energy”, “reset”])
    preferences {
    input “disableOnOff”, “boolean”,
    title: “Disable On/Off?”,
    defaultValue: false,
    displayDuringSetup: true
    input “reportInterval”, “number”,
    title: “Report Interval”,
    description: “Time interval (in minutes) for sending device reports”,
    defaultValue: 1,
    required: false,
    input “displayEvents”, “boolean”,
    title: “Display power events in the Activity log?”,
    defaultValue: true,
    input “switchAll”, “enum”,
    title: “Respond to switch all?”,
    description: “How does switch respond to the ‘Switch All’ command”,
    options:[“Disabled”, “Off Enabled”, “On Enabled”, “On and Off Enabled”],
    defaultValue: “On and Off Enabled”,
    required:false,
    input “debugOutput”, “boolean”,
    title: “Enable debug logging?”,
  • Methods *
  • updated - Called when the preferences of the device type are changed
    def updated() {
    state.onOffDisabled = (“true” == disableOnOff)
    state.display = (“true” == displayEvents)
    state.debug = (“true” == debugOutput)
    if (state.debug) log.debug "updated(disableOnOff: ${disableOnOff}(${state.onOffDisabled}), reportInterval: ${reportInterval}, displayEvents: ${displayEvents}, switchAll: ${switchAll}, debugOutput: ${debugOutput}(${state.debug}))"
    response(configure())
  • parse - Called when messages from a device are received from the hub
  • The parse method is responsible for interpreting those messages and returning Event definitions.
  • String description The message from the device
    if (state.debug) log.debug “Parse(description: “${description}”)”
    def event = [] //changed from: = null
    // The first parameter is the description string
    // The second parameter is a map that specifies the version of each command to use
    def cmd = zwave.parse(description, [0x20 : 1, 0x25 : 1, 0x31 : 5, 0x32 : 3, 0x27 : 1, 0x70 : 1, 0x85 : 2, 0x72 : 2, 0x86 : 2, 0x82 : 1])
    if (cmd) {
    event = createEvent(zwaveEvent(cmd))
    if (state.debug) log.debug "Parse returned ${event?.“inspect()”}"
    return event
  • on - Turns on the switch
  • Required for the “Switch” capability
    def on() {
    if (state.onOffDisabled) {
    if (state.debug) log.debug "On/Off disabled"
    delayBetween([
    zwave.basicV1.basicGet().format(),
    zwave.switchBinaryV1.switchBinaryGet().format()
    ], 5)
    } else {
    delayBetween([
    zwave.basicV1.basicSet(value: 0xFF).format(),
  • off - Turns off the switch
    def off() {
    delayBetween([
    ], 5)
    } else {
    delayBetween([
    zwave.basicV1.basicSet(value: 0x00).format(),
  • poll - Polls the device
  • Required for the “Polling” capability
    def poll() {
    delayBetween([
    zwave.switchBinaryV1.switchBinaryGet().format(),
    zwave.meterV3.meterGet(scale: 0).format(), //kWh
    zwave.meterV3.meterGet(scale: 2).format() //Wattage
  • refresh - Refreshed values from the device
  • Required for the “Refresh” capability
    def refresh() {
    delayBetween([
    zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 4, scale: 0).format(),
  • reset - Resets the devices energy usage meter
  • Defined by the custom command “reset”
    def reset() {
    return [
    zwave.meterV3.meterReset().format(),
    zwave.meterV3.meterGet(scale: 0).format() //kWh
  • configure - Configures the parameters of the device
  • Required for the “Configuration” capability
    def configure() { //Get the values from the Preferences section
    def reportIntervalSecs = 60;
    if (reportInterval) {
    reportIntervalSecs = 60 * reportInterval.toInteger()
    def switchAllMode = physicalgraph.zwave.commands.switchallv1.SwitchAllSet.MODE_INCLUDED_IN_THE_ALL_ON_ALL_OFF_FUNCTIONALITY
    if (switchAll == “Disabled”) {
    switchAllMode = physicalgraph.zwave.commands.switchallv1.SwitchAllSet.MODE_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY
    else if (switchAll == “Off Enabled”) {
    switchAllMode = physicalgraph.zwave.commands.switchallv1.SwitchAllSet.MODE_EXCLUDED_FROM_THE_ALL_ON_FUNCTIONALITY_BUT_NOT_ALL_OFF
    else if (switchAll == “On Enabled”) {
    switchAllMode = physicalgraph.zwave.commands.switchallv1.SwitchAllSet.MODE_EXCLUDED_FROM_THE_ALL_OFF_FUNCTIONALITY_BUT_NOT_ALL_ON
    if (state.debug) log.debug “configure(reportIntervalSecs: ${reportIntervalSecs}, switchAllMode: ${switchAllMode})”
Device specific configuration parameters
Param Size Default Description
0x01 1 0 The content of “Multilevel Sensor Report Command” after SE receives “Multilevel Sensor Get Command”.
0x02 1 N/A Make SE blink
0x50 1 0 Enable to send notifications to associated devices in Group 1 when load changes (0=nothing, 1=hail CC, 2=basic CC report)
0x5A 1 0 Enables/disables parameter 0x5A and 0x5B below
0x5B 2 50 The value here represents minimum change in wattage (in terms of wattage) for a REPORT to be sent (default 50W, size 2 bytes).
0x5C 1 10 The value here represents minimum change in wattage (in terms of percentage) for a REPORT to be sent (default 10%, size 1 byte).
0x64 1 N/A Set 0x65-0x67 to default
0x65 4 8 Which reports need to send in Report group 1
0x66 4 0 Which reports need to send in Report group 2
0x67 4 0 Which reports need to send in Report group 3
0x6E 1 N/A Set 0x6F-0x71 to default.
0x6F 4 600 The time interval in seconds for sending Report group 1 (Valid values 0x01‐0x7FFFFFFF).
0x70 4 600 The time interval in seconds for sending Report group 2 (Valid values 0x01‐0x7FFFFFFF).
0x71 4 600 The time interval in seconds for sending Report group 3 (Valid values 0x01‐0x7FFFFFFF).
0xFE 2 0 Device Tag
0xFF 1 N/A Reset to factory default setting
Configuration Values for parameters 0x65-0x67:
BYTE  | 7  6  5  4  3  2  1  0
MSB 0 | 0  0  0  0  0  0  0  0
Val 1 | 0  0  0  0  0  0  0  0
VAL 2 | 0  0  0  0  0  0  0  0
LSB 3 | 0  0  0  0  A  B  C  0
Bit A - Send Meter REPORT (for kWh) at the group time interval
Bit B - Send Meter REPORT (for watt) at the group time interval
Bit C - Automatically send(1) or don't send(0) Multilevel Sensor Report Command
delayBetween([
zwave.switchAllV1.switchAllSet(mode: switchAllMode).format(),
zwave.configurationV1.configurationSet(parameterNumber: 0x50, size: 1, scaledConfigurationValue: 2).format(), //Enable to send notifications to associated devices when load changes (0=nothing, 1=hail CC, 2=basic CC report)
zwave.configurationV1.configurationSet(parameterNumber: 0x5A, size: 1, scaledConfigurationValue: 1).format(), //Enables parameter 0x5B and 0x5C (0=disabled, 1=enabled)
zwave.configurationV1.configurationSet(parameterNumber: 0x5B, size: 2, scaledConfigurationValue: 5).format(), //Minimum change in wattage for a REPORT to be sent (Valid values 0 - 60000)
zwave.configurationV1.configurationSet(parameterNumber: 0x5C, size: 1, scaledConfigurationValue: 5).format(), //Minimum change in percentage for a REPORT to be sent (Valid values 0 - 100)
zwave.configurationV1.configurationSet(parameterNumber: 0x65, size: 4, scaledConfigurationValue: 14).format(), //Which reports need to send in Report group 1
zwave.configurationV1.configurationSet(parameterNumber: 0x6F, size: 4, scaledConfigurationValue: reportIntervalSecs).format(), //Send Report to group 1 for this interval (Valid values 0x01‐0x7FFFFFFF)
  • Event Handlers *
  • Default event handler - Called for all unhandled events
    if (state.debug) {
    log.debug "Unhandled: $cmd"
    createEvent(descriptionText: “${device.displayName}: ${cmd}”)
    } else {
  • COMMAND_CLASS_BASIC (0x20)
  • Short value 0xFF for on, 0x00 for off
    def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
    if (state.debug) log.debug "BasicSet(value:${cmd.value})"
    createEvent(name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”, displayed: true, isStateChange: true)
    def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
    if (state.debug) log.debug "BasicReport(value:${cmd.value})"
    createEvent(name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”)
  • COMMAND_CLASS_SWITCH_BINARY (0x25)
    def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinarySet cmd) {
    if (state.debug) log.debug "SwitchBinarySet(value:${cmd.value})"
    createEvent(name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”, displayed: true, isStateChange: true)
    def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
    if (state.debug) log.debug "SwitchBinaryReport(value:${cmd.value})"
    createEvent(name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”)
  • COMMAND_CLASS_METER (0x32)
  • Integer deltaTime Time in seconds since last report
  • Short meterType Unknown = 0, Electric = 1, Gas = 2, Water = 3
  • List meterValue Meter value as an array of bytes
  • Double scaledMeterValue Meter value as a double
  • List previousMeterValue Previous meter value as an array of bytes
  • Double scaledPreviousMeterValue Previous meter value as a double
  • Short size The size of the array for the meterValue and previousMeterValue
  • Short scale The scale of the values: “kWh”=0, “kVAh”=1, “Watts”=2, “pulses”=3, “Volts”=4, “Amps”=5, “Power Factor”=6, “Unknown”=7
  • Short precision The decimal precision of the values
  • Short rateType ???
  • Boolean scale2 ???
    def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
    def meterTypes = [“Unknown”, “Electric”, “Gas”, “Water”]
    def electricNames = [“energy”, “energy”, “power”, “count”, “voltage”, “current”, “powerFactor”, “unknown”]
    def electricUnits = [“kWh”, “kVAh”, “W”, “pulses”, “V”, “A”, “Power Factor”, “”]
    if (state.debug) log.debug “MeterReport(deltaTime:${cmd.deltaTime} secs, meterType:${meterTypes[cmd.meterType]}, meterValue:${cmd.scaledMeterValue}, previousMeterValue:${cmd.scaledPreviousMeterValue}, scale:${electricNames[cmd.scale]}(${cmd.scale}), precision:${cmd.precision}, rateType:${cmd.rateType})”
    //NOTE: ScaledPreviousMeterValue does not always contain a value
    def previousValue = cmd.scaledPreviousMeterValue ?: 0
    def map = [ name: electricNames[cmd.scale], unit: electricUnits[cmd.scale], displayed: state.display]
    switch(cmd.scale) {
    case 0: //kWh
    previousValue = device.currentValue(“energy”) ?: cmd.scaledPreviousMeterValue ?: 0
    map.value = cmd.scaledMeterValue
    break;
    case 1: //kVAh
    break;
    case 2: //Watts
    previousValue = device.currentValue(“power”) ?: cmd.scaledPreviousMeterValue ?: 0
    map.value = Math.round(cmd.scaledMeterValue)
    break;
    case 3: //pulses
    break;
    case 4: //Volts
    previousValue = device.currentValue(“voltage”) ?: cmd.scaledPreviousMeterValue ?: 0
    break;
    case 5: //Amps
    previousValue = device.currentValue(“current”) ?: cmd.scaledPreviousMeterValue ?: 0
    break;
    case 6: //Power Factor
    case 7: //Unknown
    break;
    default:
    break;
    //Check if the value has changed by more than 5%; if so mark as a stateChange
    map.isStateChange = ((cmd.scaledMeterValue - previousValue).abs() > (cmd.scaledMeterValue * 0.05))
    createEvent(map)
  • COMMAND_CLASS_SENSOR_MULTILEVEL (0x31)
  • Short sensorType Supported Sensor: 0x04 (power Sensor)
  • Short scale Supported scale: 0x00 (W) and 0x01 (BTU/h)
    def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
    if (state.debug) log.debug “SensorMultilevelReport(sensorType:${cmd.sensorType}, scale:${cmd.scale}, precision:${cmd.precision}, scaledSensorValue:${cmd.scaledSensorValue}, sensorValue:${cmd.sensorValue}, size:${cmd.size})”
    def map = [ value: cmd.scaledSensorValue, displayed: false]
    switch(cmd.sensorType) {
    case physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport.SENSOR_TYPE_POWER_VERSION_2: // 4
    map.name = "power"
    map.unit = cmd.scale ? “BTU/h” : "W"
    map.value = Math.round(cmd.scaledSensorValue)
    break;
    case physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport.SENSOR_TYPE_VOLTAGE_VERSION_3: // 15
    map.name = "voltage"
    map.unit = cmd.scale ? “mV” : "V"
    break;
    case physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport.SENSOR_TYPE_CURRENT_VERSION_3: // 16
    map.name = "current"
    map.unit = cmd.scale ? “mA” : "A"
    break;
    default:
    map.name = "unknown sensor ($cmd.sensorType)"
    break;
    createEvent(map)
    }[/code]
I prefer control in seconds so I updated the following:
// description: “Time interval (in minutes) for sending device reports”,
description: “Time interval (in seconds) for sending device reports”,
and
// reportIntervalSecs = 60 * reportInterval.toInteger()
reportIntervalSecs = reportInterval.toInteger()
Do you know how to get the output to appears as it does in the “Aeon Home Energy Meter” type?
The device I have it plugged into is using 143W but it doesn’t show in the logs
"“Aeon Home Energy Meter”
5:39:04 PM: debug Parse returned Aeon Home Energy Meter energy is 672.454 kWh
5:39:04 PM: debug Parse returned Aeon Home Energy Meter power is 1275 W
vs
5:42:38 PM: debug Parse returned null
5:42:38 PM: debug MeterReport(deltaTime:10 secs, meterType:Electric, meterValue:3.077, previousMeterValue:3.077, scale:energy(0), precision:3, rateType:1)
5:42:38 PM: debug Parse(description: "zw device: 0F, command: 3202, payload: 21 64 00 00 0C 05 00 0A 00 00 0C 05 ")
5:42:28 PM: debug Parse returned null
5:42:28 PM: debug MeterReport(deltaTime:10 secs, meterType:Electric, meterValue:3.077, previousMeterValue:3.075, scale:energy(0), precision:3, rateType:1)
5:42:28 PM: debug Parse(description: "zw device: 0F, command: 3202, payload: 21 64 00 00 0C 05 00 0A 00 00 0C 03 ")
I’ll look at it next time I’m home and the washer is in use (that’s what’s connected to the Aeon unit). Offhand though, I think you’re going to have reliability issues with reporting every second (cloud overload). Besides which, there’s really no point in doing so, since you can’t schedule anything to happen in ST with that kind of precision.
http://docs.smartthings.com/en/latest/smartapp-developers-guide/scheduling.html#limitations-best-practices
@Mr_Lucky
I just installed the device handler you posted above… I’m not sure if this is going to do what I need…
Here is my scenario:
I have automations in my master bedroom for the lights and stuff. My wife has a place set aside in our room where she goes to utilize her breast pump. During the times that she is there doing that she does not want the lights going off and on from the automations.
So, I connected the pump to this plug in switch. It works great with stopping the automations, with one exception. It takes a bit of time before it starts reporting that it has a power load, so in that time the automations are still active.
How quickly will this DH start reporting the load starts and stops? I’m looking for something that reports right away, or at least within a minute.
@bamarayne,
You can try using my device handler if you’d like. It contains a couple of the preferences the one above uses (enable/disable debug and disable/enable the switch), but mine does all the parameter configurations manually at the bottom of the code (which was my personal choice).
Here’s the code:
https://raw.githubusercontent.com/constjs/jcdevhandlers/master/devicetypes/jscgs350/my-aeon-metering-switch.src/my-aeon-metering-switch.groovy
Look at the configure() section at the end.
The device is set to only report when there’s a 2 watt change (parameter 4) or 1% change in watts (parameter 8). All that is controlled by parameter 3 being 1.
Changing parameter 3 to 0 will cause the device to report every 15 seconds (parameter 111) for watts, and every 60 seconds for kWh (parameter 112).
If you decide to change anything, be sure to tap on the Configure tile in the phone app.
Thanks for sharing the code, however, I’m trying to get the auto-report every 15 seconds and 60 seconds and doesn’t seem to be working (I’m not getting the two reports event) I’m only getting the kWh every 60seconds (not the 15sec). I did changed parameter 3 to 0 and I did click configure.
I can’t see any documentation for that parameter 3 in the aeon specs doc: http://www.pepper1.net/zwavedb/uploads/resources/1f5c804cf92d4797dda2d142a452035ba0aefe99.pdf perhaps I’m having an old document ? Where did you find the behaviour of param 3, if you could provide a doc, that would be great !
Is there anyway to change the physical device to have instant on and off instead of the slow dim?
I think you’re talking about a different Aeon device, as in their microswitch. This thread is about this one:
Ooppps sorry, your right. Wrong thread
Good catch Jonathan, you are absolutely correct. I copy/pasted from my HEM code and lost the right parameters for the SES. I just fixed all that, plus I documented them a little better in the code:
Just change parameter 90 to 0. Be sure to tap on Configure again.
Just tried to add this and get a weird error, any thoughts?
Org.springframework.dao.DuplicateKeyException: a different object with the same identifier value was already associated with the session: [physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)]; nested exception is org.hibernate.NonUniqueObjectException: a different object with the same identifier value was already associated with the session: [physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)]
Hi @michaelahess, that looks like an issue with the IDE perhaps? Try closing down all your browser sessions, and try again. If that still doesn’t do it, make sure you don’t already have a device handler called “My Aeon Metering Switch”. If you do, edit that one, or give this one a different name.
Yeah looks like the one I had by Mr Lucky, was causing the complaint, just over wrote it and it worked great. I usually try to keep the old and new device type around in case I have to change it quick. Thanks for the advice!
I already have this functioning under the generic Z-Wave Metering Switch device type. When I try to change it to This new device type I get the following error. Am I missing something? It’s a pretty generic error. I’m not really sure where the problem lies.
Oh No! Something Went Wrong!
Error 500: Internal Server Error
URI /device/update
Reference Id 48350cae-5faa-4ece-899e-096e93f68a05
Date Tue Mar 08 22:16:03 UTC 2016
Hi @theeric,
Odd, but we can figure out what’s going on. I could just be a hiccup with the IDE, so did you try closing your browser sessions and starting again? Also, you don’t happen to have another device handler called the same thing do you?
I tried closing my browser as well as checking that I don’t have any other device handlers with the same name. I was able to get “elasticdev : Aeon Labs Smart Energy Switch” to work just fine with this device. I only get the error message when I try to load “jscgs350 : My Aeon Metering Switch”
John, I tried a pile of code, and about 5 other device handlers. This one did the trick! I needed pretty much instant power change updates to have these power switches work correctly for my little app. Thanks so much!
Know this is an older post - but just received 2 of these and still looking for the best DTH. Like this for fast reporting, but need a reset-able cumulative KW - have not seen one with both.
