Hi all,
I’m hoping to share my experience converting from a v2 hub to a SmartThings ADT panel in an effort to save others the glitch I experienced. But first I want to compliment Ryan and the SmartThings support team for helping me through it. They were great!
The transition went fairly smooth and I was even able to pair the ADT sensors with only a few hiccups, mainly just learning curve. I had the system operational and signed up for ADT monitoring. The problem came when after several days I decided to add an ADT keyfob. I paired the keyfob with the panel, renamed it and thought I had it. Every time you add an ADT device you have to run the panel through a system test with ADT where you place the panel in test mode, arm the panel, and set off an alarm. Amid the noise you then trigger each sensor and make sure ADT sees it by looking for a check mark beside the sensor in the SmartThings app. You can’t use the alarm side until you pass the test. All went well except for my newly added keyfob. Assuming there was a pairing problem I removed it and re added it. On the next system test ADT showed I now had two keyfobs and I couldn’t clear either by pressing any button on the keyfob. One little piece of info left out of the instructions, but found in this community, is that the test is looking for the panic activation on the keyfob, which consists of holding the Stay and ‘*’ buttons both down for three seconds. On the next system test I was able to clear one keyfob, but not the other.
I finally contacted the SmartThings support team (after no luck with ADT) and Ryan stayed with me as we tried a variety steps to clear the erroneous keyfob and allow me to pass the system test. I was impressed with his knowledge on the SmartThings side of things and we both concluded the problem was on the ADT side. After no luck Ryan found a reference to “phantom devices” and ADT Canopy. He didn’t have much other info and I told him I had never heard of Canopy. His info mentioned logging into Canopy so in desperation I googled ADT Canopy and found a login screen. I tried my ADT login and it worked. Once in, I could see my ADT account info, contact info, and most importantly my monitored devices. Under that tab I saw all my monitored devices including the phantom keyfob. I was able to delete it and the pass the ADT system test and restore service.
Morale of the story… No where in the directions, instructions, or elsewhere was there ever a mention of ADT Canopy. Everything referred to managing your ADT account through the SmartThings app. BUT if you have the SmartThings ADT panel you have access to your account and some very important info through ADT canopy.
While I enjoyed the afternoon speaking with Ryan at SmartThings support, I hope to save others the time if you too have a case of PHANTOM DEVICES…
