Turning off device health instantly fixed it for me. Thank you so much!!! This has been driving me crazy!!!
Just had every Z-Wave device go unavailable (about 25 different devices mostly switches & relays). No luck on any of the solutions mentioned on the thread, including, disabling device health, power cycling hub, physical reset and shutting down every breaker in the house, z-wave repair, IDE updates, and donāt really want to attempt to remove and re-add (itās a ton of rules).
All zwave devices show failed to update mesh info.
Update: the majority of my zwave motion and door sensors are also not responsive. Oddly the front door is still somewhat responsive (and itās further from the hub than most) But a good 15 other motion/door are not.
Any ideas?
Adding this to another post as well, as Iām hoping someone else finds this as useful as I didā¦
I reached out to support and they helped me resolve my issue. Below were the exact steps. Took several tries, but everything is working now without having to delete any devices or rules. Note that per the steps below, it doesnāt actually add any devices in the āadd a new thing screenā and the add device screen wonāt update, it will continue to pinwheel and say looking for devices, but the already added device came back online for me after power cycling a few times. Hope this helps someone else!
Here are the steps:
"What I am going to have you do for any future and current offline devices is to perform a ārejoinā of the device. A rejoin basically tells the device to look for the best possible connection for that one device as opposed to the āz-wave network repairā which tells all devices to look. I wouldnāt do any more repairs at this point as that resets all the connections that this rejoin will repair.
Here is how to do a rejoin of offline or non-working z-wave devices:
First, put the Hub in inclusion mode. Do this by tapping on the āMy Homeā tab, going to the bottom of the āthingsā list, and then tapping on āadd a thingā. While it is in this ālooking for devicesā screen, go to step 2.
On any device that is offline, please simply switch it on and off a few times. Start with the devices that are closest to the Hub first. This should get the device to show up again as online and should get it to find a new connection point to the Z-wave network. Please repeat this for any devices that fall offline or do not respond to commands. Make sure to not do a Z-wave network repair as it will break these new connections. Once finished rejoining a device, exit the āadd a thingā screen and see if the device responds and is online after about 20 seconds. Note: you will not see any devices getting added on this ālooking for devicesā screen, it is simply used for getting the Hub in the right mode.
Go ahead and try that out for any of your offline or non-responding devices and let me know if you are having issues getting them back online."
This solved it for me. Thanks.
Let me get this straight⦠While the SmartThings hub is looking for new things, I turn the light switch on and off a couple times, right? Not the breaker to the switch itself?
Should the app give me any indication that it has built a new path for the switch? Or do I just do it a couple times then exit the āAdd new thingsā search and assume itās good to go?
The reason I ask is that when my switches randomly become unavailable/offline/not responding, every few days, usually just turning the switch on or off at the wall is enough to make it start responding to the app again, but they go non-responsive again in a few days.
I just canāt get my head around a home AUTOMATION/CONVENIENCE device that requires me to screw around with it every few days. Thatās the opposite of automated or convenient. LOL.
I am experiencing the same issue with one of my new GE Zwave-Plus switches. The switch randomly becomes unavailable and a tap of wall switch brings it back to life. I have tried all of the troubleshooting and nothing permanently fixes the issue. I also have two other GE switches that never have an issue, Like Jesse17 said,
Iām having this issue as well with Multiple devices
thanks, that indeed did the trick.
Just wanted to add my feedback. Doing the general device exclusion, then doing the āreplaceā also fixed my issue. Thanks!
I had a simlar issue with a GE Byjasco motion switch. With this custom device handler Jasco/GE Motion Switch 26931
I have a few of these switches using this same device handler but havenāt seen this problem with them.
Iām assuming something went wrong with a firmware upgrade.
Because this device was labeled with Device ID 11, found on my hubs website https://graph.api.smartthings.com/, but in the log i noticed alot of traffic from a device ID 33. so i went looking for it in the My Devices menu, but couldnāt find it. So I decided to run an exclusion and turned my Unavailable motion switch on off. I noticed that Device ID 33 was excluded. Then I rejoined the Motion switch, works fine now.
So to me this looks like a firmware upgrade somehow got this device assigned a new Device ID, but smartthigns saw it as a different Device ID, giving it an unavailable status.
I had a similar issue with a Lutron light switch. Flipping device health off and back on seemed to fix it.
