I try to connect an Fibaro dimmer 2. have tried to exclude and include it. but in the App it does not find anything.
But in the live logs and event i see it as “Fibaro Dimmer 2” and inder inclusion i see an event that it is rejoined. but when I press the physical button it gives an error in live log. see pictures.
Thanks. after rebboting I was able to exclude the device. got an message in the ST app that a device was excluded. but when i tried to add it again i still got the same rejoined event. but no visible device
Hi, I’m following up on this to see if you ever found the resolution. I’m having the same issue with 3 different Kwikset locks- both old and new. This is the only thing I’ve found so far on the internet relating to my issue. Thanks!
Are you using a custom device handler for it? If yes, login to IDE and open that device handler and Choose Publish for Me. Then exclude the device again and try to pair it. There is a known issue where device handlers become stale preventing users from pairing devices that use it. Anyway, something to try.
