I bought this new zigbee 3 pir, product ZM-35ZH-Q. It gets detected as a thing and then i’ve manually tried changing the device type, firstly as a Zigbee motion sensor then as a Smartsense motion sensor.
When I test it I can see it the logs are written as below so clearly it can detect motion but when I try and configure a routine with it in ST it doesn’t do anything, does anyone have any suggestions?
Although you could use a DTH today, be aware that support for those is shutting down soon, so you might want to just start with an Edge Driver since those are part of the new architecture.
That’s the right list, did you ask in this thread? (The image is the quick browse list for Edge Drivers for sensors, the same one you linked to). At least that author has been working with Tuya sensors, so they may know if anyone is working on the PIR devices.
