Tuya door sensor driver
Sorry if I repeat any question here but I haven’t found this device in a search.
I’m fairly new to ST and I’m transferring all my Zigbee devices from an Eero hub to a V3 hub. As this is a really great active community site I’ve found Edge drivers for virtually everything, except for these Tuya door/window sensors that I have.
They just pair as a Zigbee Thing with this information and I don’t know if it’s not possible or I’m missing something. Thanks for anyone’s help.
Hi @Johnnybegoode
Added to this driver version
 Name         Zigbee Contact Mc
 Version      2022-12-24T14:18:56.276630174
- id: "_TZ3000_n2egfsli/Close Sensor"
    deviceLabel: TS0203 Close Sensor
    manufacturer: _TZ3000_n2egfsli
    model: TS0203
    deviceProfileName: contact-battery-profile
Thanks Mariano - that’s amazing! Can’t wait for the driver update (every 12 hours I saw somewhere) to try it out, finish my device transfer and set up my routines.
Happy Christmas - Felices Fiestas!
If you can’t wait for the automatic update, you can either install it manually with the CLI or uninstall old driver versión from the hub and reinstall it from the channel, which is already updated.
To delete the driver you have to uninstall all the devices that are paired to the driver or change them to the Zigbee Thing Mc driver until you install the new version
Merry Christmas
@Johnnybegoode Did the driver work for tuya contact sensor?
I have 6 of them, bought at different times, and 5 run perfectly with @Mariano_Colmenarejo 's driver. The last one apparently has a different “cluster” which can use I believe a driver by @w35l3y but that more involved and I’ve left it for the moment. It looks exactly the same as the others.
Did you try that generic driver you mentioned ?
I tried without success before but as you got back to me today I’ve attempted pairing again.
It pairs as a Generic Device to the Default clusters driver, and there isn’t any alternative if I try the alternative driver option. I select Contact Sensor but it doesn’t update…
Thanks for your interest.
HI @Johnnybegoode
This device use standard clusters, it must works with my driver.
I will add to it
 Version      2023-03-14T14:02:24.554453917
- id: "_TZ3000_ebar6ljy/Contact Sensor"
    deviceLabel: TS0203 Contact Sensor
    manufacturer: _TZ3000_ebar6ljy
    model: TS0203
Fantastic!
Thanks to @Mariano_Colmenarejo and @w35l3y for following up what was only a reply to a post, and then solving it in record time. I’ll be waiting for it to update before trying to re-pair tonight when I get in.
:+1:
I have the same sensor but I can’t get it to connect. It has some different characters after the TZ3000 when I look.
I can’t find the screen where everyone else has taken a screenshot but I have this one
Am I doing something wrong or does it also need adding to the driver?
Hi @Standingformation
Your device exist in my driver Zigbee Contact Mc
You need to install the driver in your Hub from my Channel, in this link
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
Uninstall the device from App
Add new device from app with search nearby option
Device will appears in the room where the Hub is
Thanks for the quick reply!
I had already installed your driver from your channel but it still paired as Thing.
I just deleted it and tried again and worked perfectly.
Thanks for all your hard work!
Hello, Im having the same issue with these door sensors. I do have your channel and have installed the driver, When I got to install this driver I get the following message: error changing device driver to “Zigbee Contact Mc”. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.
Hi @lmd569
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
Thank youa
I have a few of these devices and they also only show as 'thing". I am installed the latest driver contact MC and re paired the devices multiple times It just will not show up to let me choose the contact driver.
Hi @Jay_Z
 Version      2023-08-07T19:54:25.549832446
- id: "_TZ3000_yxqnffam/Contact Sensor"
    manufacturer: _TZ3000_yxqnffam
    model: TS0203
Thank you very much!
I have another one of those pesky TUYATEC Contact. Here is the info i have… Can you add it to driver?
Model
RH3001
Type
ZIGBEE
Presentation ID
bc813f60-efa1-3d89-896d-93ef64cf89c8
Manufacturer Code
TUYATEC-ycbe5fbx
