The latest iOS ST app keeps logging me out
I am right there with you - I am having the same issues with the app logging me out. I have also experienced some of the other odd problems like it rearranging things. The latest issues with the app have me considering jumping ship and moving to something else as well.
Above all else, I want a reliable home automation system. I believe the maturity of the ST platform is one of the reasons so many people use ST now. But it seems like that is becoming less of a priority for ST.
I just got an update ā€œBug Fixesā€
Same here. Got updated from Version 1.6.75-582 to 1.6.76-584. Hopefully that fixes it the problem.
Same and the app is getting slower than older versions.
Signs me out daily and forces two factor signin which I dont want…….what moron implemented this, it’s basically broken the app.
This app is simply not reliable which is a red flag for a light switch. is there an alternative universal hub?
I don’t see any responses from my previous post. Has anyone gave this a try, and if so, did it fix it?
I have 2FA enabled, and on the third day after the previous app update promoting for login, the SmartThings app made me re-save the SmartThings credentials on my iPad. Since then it hasn’t asked for the the login again. I believe it’s the Samsung.com entry in the iOS passwords settings that where saved, although that might not be it either.
Did the update fix it for you? I’m still getting logged out.
I tried doing as you suggested and that didn’t fix the issue. The problem isn’t that the password isn’t saved in a password cache like iOS passwords or other password manager. The app shouldn’t log out when loading.
When this happens for me, for about 1 or 2 seconds, the app appears normal with my favorites showing, etc. Then, suddenly the app hiccups and reverts to the login screen. I wonder if others are seeing the same behavior. I had a longer password for my Samsung account with special characters. I’m trying changing it to only 15 characters with just letters and numbers only to see if that helps. It’s interesting that while many are having this problem, others aren’t, so I wonder if that’s related. Do others that are having this problem have passwords containing special characters?
Yes, and with 2FA enabled. I also have Android devices connecting to SmartThings too.
My iPad stopped prompting for login on the third day when it prompted me to save the SmartThings credentials again which it had not done on the previous two days after the update. I recall that on the third day that I was so frustrated that I kept killing the SmartThings app without logging in more than a few times, before I finally logged into the app which it then asked me save the credentials again.
I opened the app today and for the first time in days, it didn’t log me out.
I uninstalled and reinstalled the app yesterday so maybe that fixed it? Crossing my fingers.
Or maybe that’s iCloud Private Relay
Well, changing to a simpler password without special characters had no effect. The app logged out again on me this morning when opening it. @boomshaka, good luck to you but I’ve done the same many times in the last few weeks and it hasn’t helped. I’ve also disabled and re-enabled 2-factor hoping that action would reset something and it didn’t help either. It almost seems like there’s an unhandled exception that the app is hitting at some point when loading that is causing it to reset webcredentials saved in the app.
3rd day in a row that I haven’t been logged out since uninstalling and reinstalling the app. Try it guys.
Sad to say it’s still doing it for me with latest app version and latest iOS. Just had to log in this morning. Interestingly, the app opened and let me surf around a bit before freezing up and then calling for the login. Way to go - make me think I’m doing alright and then surprise me when I least expect it.
Do you have two-factor enabled or not?
Every single day. I’m already on the latest 1.6.76 iOS app released five days ago.
Frankly, that annoying bugs stay for so long show how little care new and old users receive from SmartThings today.
I do have 2FA enabled. You tried uninstalling the app too?
Many times. Maybe it’s time to try two-factor to see if it resolves it.
Same issue here. I have to login daily. 2FA enabled. In the off-chance I don’t get prompted to login I’m required to agree to user terms.
I’m planning to migrate off SmartThings, just been too lazy.
I’m finding that the best part of this bug is that you don’t know you are logged out until you spend 5 minutes running and rerunning and editing scenes because they don’t work when you run them and generate only a cryptic red exclamation point. Then you exit the app and reload it, and what do you know, request to log in.
Absolute piece of crap.
I recently move from Android to iOS & Having the same issue on my iPhone 13.
The funny part is every time I log in again (with 2FA), Samsung sends me an email with the subject line ā€œThanks for Your Purchase Registrationā€ with Model: iPhone and serial number : New serial number every time.
Please make the app show a sign-in msg as soon as the user opens it (if you can not stop the sign-out issue) and make face id enable for iOS users. So users don’t have to go thru all the processes.
