Has anybody had any z-wave device auto-migrate yet? Most comments in here seem to be zigbee devices.
No I created VR device to act as a placeholder inside my routines. I added the VR devices in set it with the same settings(on, off, dim, etc). The removed the old device repaired with driver and then did the same procedure over. To manage the routine editing. I when into the device itself and then. The routine tab. This allowed me to edit all routine that device interacted with. Then once I was ready to repair I did the same thing with the VR device. Doing it that way kept me from search through over 160+ routines.
Now editing the sharptools rules was a bit more lador involved but I still got it done. At the same time I rebuilt all my webcore pistons.
My Aeotec Siren gen5 was migrated in the in july beta phase
Yes, eight (8) switches and/or dimmers in total.
No, none yet.
Except for SmartLighting rules, or scenes, or outside integrations, or smartappsā¦
Yes - the Z-wave repeater component of two Iris Z-wave / Zigbee smart plugsā¦does that even count?
I have the following that have not yet migrated, and I have my fingers crossed that they eventually will without me having to do it manually.
6 - NuTone NWD500Z Smart Z-Wave Enabled Wall Dimmer Switch
2 - Zooz 700 Series Z-Wave Plus On/Off Switch ZEN71
1 - Zigbee Switch,Inle Smart Light Switch
1 - Enbrighten Z-Wave Plus Smart Outdoor Switch, 1-Outlet Plug-In (2nd Gen.)
1 - GE 14284 Enbrighten Z-Wave Plus Smart Outdoor Switch
I have a Zen26 that auto-migrated to the SmartThings Z-wave Switch driver.
Iām assuming the reason that things are going slower than planned is they are either running into issues or have not gotten to all of the drivers due to the amount of effort involved. Iām in no rush to push something that may not be ready for prime time. Iād rather keep everything up and running smoothly, which with roughly 15 devices automatically transitioned so far, has been the case. Iāve heard a number of stories about running into memory/device limits and thus would rather have the bare bones install first, at which point, then I will consider if I should upgrade to some of the more comprehensive drivers. Iād be naive if I didnāt think there will be issues towards the one offs towards the end of the process though.
Multiple people have had zwave thermostats migrate which then didnāt work.
Known issue, engineering is looking into it.
Thermostat problems (multiple brands) Nov 2022
Also, multiple people have had some GE zwave dimmer switches migrate which then didnāt control the level correctly. There is a community-created edge driver for those which does fix the problem.
Jasco/GE Dimmers stopped 'remembering' last setting since migration to stock Edge Driver
itās not that zwave devices are more likely to have problemsājust that people are more likely to post about problems, so those are the examples Iāve seen.
my GoControl Z-wave siren migrated to Z-wave switch ( and not non-functional).
I do have 2 z-wave siren edge driver downloaded but when I try to change driver for this GoControl Z-wave siren, it doesnt show any siren specific edge driver.
I tried to migrate my zwave Kwikset lock with the edge driver that was supposed to work but the lock wouldnāt unlock or lock. So I had to reset it with the old driver it was using. Waiting for auto migration and hoping it works.
Yes - I had one Z-wave Aeon relay switch migrated yesterday to a SmartThings Switch driver. It didnāt work but changing to a Mariano one I had installed already seems to have fixed it.
I have quite a few of these relays so Iām surprised that only one has migrated, but maybe they are slightly different models.
Other people have reported that not all of their identical devices migrated at the same time.
There are several possibilities for that.
Smartthings may be doing the migration gradually, we just donāt know all the details.
Since migration also involves your automations, itās also possible that some of your devices have more complex automations than others.
Or, as you mentioned, they might have slightly different fingerprints.
I have 28 Zwave devices that have auto migrated and 57 other devices that still have not migrated. 15 of them that have not migrated are identical to other devices that auto-migrated.
Totally with you there! Most of the instructions Iāve seen for hand-migrating start with āfirst subscribe to the SmartThings beta Edge driver channelā. No, thank you.
Does anyone know whether devices have to be online for successful migration? I have a handful of items that are offline, like sensors that Iām not currently using but havenāt excluded. Coincidentally, none are the same model as devices that have been migrated (and weāve seen that not all devices of the same type/model migrate at the same time), so I canāt refer to that as a benchmark. Theyāre obviously not critical devices for me, or they would have been online; Iām just curiousā¦
A have a linear garage door opener that has been offline for a year that migrated.
just checking⦠offline?
