The End of Groovy Has Arrived
Perfect - thank you.
Hi @h0ckeysk8er - Can you provide any feedback on how your routines are working?
I only ask, because with the pre-edge routines I had tried many times to create logic like:
If motion detected + light = off; then turn on light for 15 minutes
In an example like that, the light turns on for 15 minutes, then turns off as expected. The routine would also run if the light was ON, and then turn off after 15 minutes also … kind of ignoring the pre-condition.
Can you post a screenshot of your routine?
Depends on what point in time you tried to create those routines with the app, what driver you were using for the motion switch, and if your motion switch has different modes like mine does. Hard to diagnose without more info. If you look at my post above, I provided screenshots of my routines and info on the drivers I’m using for the virtual switch and motion dimmer/switch.
They are posted earlier in this thread.
Where’s the best place to ask cli questions? I’m not able to find a relevant thread??? I’m getting a lot of ā€œno items foundā€ type responses… Thanks.
Developers Programs > possibly Support
Thanks - I do see some CLI posts in there so that’s a good starting point!
Well disaster has begun!
All of my 3 ST Buttons (IM6001) failed today! Still display temp but pressing does nothing. Depower and reconnect does not fix. Forgetting and re Scan also does not fix - totally useless!
Added 2 new buttons and each setup differently! One onlined the same as normal but without the TempOffset setting, the other came online with both the tempOffset and a ā€œDriverā€ entry showing ā€œZigbee Buttonā€ driver.
Interesting as I am not supposed to get Edge capability on my ST Wifi hubs till next week!?
Instantly 3 useless Buttons.
Exact same happened to me. Buttons are no longer working.
My minimotes stopped working
I’ve been using the SmartThings Edge Beta Zwave Button driver for a while and my AEON (Areotec) Minimotes are working fine.
My ST buttons are all still working fine and all three appear to still be on the stock DTH.
last night one of my 20-25 buttons stopped working. this morning i removed/re-added it then it started working again.
15 October 2022. Status page reports a platform outage:
Discussion thread:
For me, my schlage lock doesn’t seem to report event anymore
Is there a way to see if we are migrated yet or not ?
Two ways to check….
  • in IDE if the device displays Placeholder then it is using an Edge Driver or is a cloud to cloud integration using the new architecture.
  • in ST app, open the device, tap More Otpions (3 dots in the upper right) and if you see Driver listed in the submenu them it is using an Edge Driver. It does not appear in the su menu if the device is not using an Edge Driver.
What is the plan for HomeSeer switches with scene control, and double tap, etc?
Ask Homeseer support.
So far they have said they are working on edge Drivers for the series 200 and above devices, but not the older devices which are no longer sold.
