Tahoma somfy
Is there a way in Europe to integrate the products connected to the Tahoma Somfy (shutters controlled RF motors, Velux products) into ST?
C’è un modo in Europa per integrare in ST i prodotti collegati al Tahoma Somfy (serrande controllate con motori in RF, prodotti Velux)?
Hey mate, i use a Bond Bridge. https://bondhome.io it works great and has long range replacing all the RF Somfy remotes.
thanks but since I already have the Tahoma I don’t intend to equip myself with another hub or bridge, I was looking for a way to make Tahoma communicate with ST
Sorry, I’ve now seen that they have implemented the service and it works. Thank you all
Hi
You’ve probably just seen this
https://www.somfy.fr/a-propos-de-somfy/partenaires-et-compatibilites/partenaires-connectes/samsung-smartthings
I suppose that this is valid for the European market and would presume that being completely cloud based it will control all motor types, blinds and awnings, both the older RTS and newer iO RF868 and even the curtain motors
There is however also a community driver here
which runs I think locally, although I don’t know if it covers all types as Somfy has various systems depending on geographical zone.
