Anyone successfully connect Tahoma Hub controlled devices to Smartthings hub using this z wave dongle? Tried emailing Somfy and they could only confirm it could connect z wave devices to the Tahoma hub, but the couldn’t confirm if it could connect the smartthings hub to it.
https://shop.somfy.co.uk/z-wave-usb-module
Did it finally succeed? I am also looking for a usb stick to connect my str somfy. Hope to hear from you
I never tried! There are now some somfy devices that are compatible with Smartthings, but not the rts blinds like I have. Found creating routines in Alexa and using a virtual switch in Smartthings allows me to use Smartthings for automations and Alexa for voice control and sync the blinds open/close status between the two.
