just purchased a Somfy motorised roller blind (indoor) and am thinking of getting several more.
I read an article on here about integrating with Smartthings that refers to a ZRTSI hub, but Somfy appear to only offer Conexoon and Tahoma hubs at the moment.
Tahoma appears to link directly to Alexa so I am guessing that is the way to go. I think i’m only really wanting voice control rather than automation but Im sure that will change one day
Here you go Ian - The fact the model number has RTS in it means it uses Somfy’s RTS tech - and there fore you’ll need an RTS hub or bridge. Both the Connection and Tahoma should both be able to do RTS.
That said I prefer straight up Zwave Somfys (Somfy motors go in Springs Window Fashion Blinds, which are also marketed as Graber and Bali) I got all mine from Zebrablinds: https://www.zebrablinds.com/smart-homes
Be aware that there are two versions, an older one (avoid) and the updated one (16 channel, with LCD display and 2 buttons on the front). Avoid the older one.
I bought mine about a year ago on eBay for about $120 USD. They are becoming hard to find. Again, note that they are US frequency Z-Wave.
Hi Ian — great choice going with Somfy, they’re one of the more reliable brands.
You’re right: the ZRTSI hub is the older option and not widely available anymore. Somfy now primarily supports Tahoma and Conexoon for smart integration.
If you’re just after Alexa voice control, Tahoma is the better choice. It connects directly to Alexa and Google Home without needing a middle layer like SmartThings. You can always add automation later (scenes, timers, etc.).
One thing to keep in mind: most of Somfy’s motors still use RF (Radio Frequency), so Tahoma acts as the translator between your smart home and the motors — Alexa doesn’t talk to the blinds directly.
We help people retrofit and upgrade Somfy systems regularly — if you’re curious about the difference between RF and Zigbee systems (like Tuya or Smart Life), we wrote up a guide here: motorisemyblinds.com.au/rf-vs-zigbee
(Hope it’s okay to share — not a sales link, just an explainer as I am in Australia.)
