As you can see in the pictures, my ST scene only allows me to lock the door. I want it to lock at night and unlock in the morning. Any tricks?
That feature is not available in the STSC app. You can do this in the ST Classic app.
Well that stinks lol.
I’ve heard much greater things are possible in the Classic app.
Should I switch over or will the new app be the standard soon with all the good features?
The problem is, I was told I cannot connect the Yale lock to both smart things AND Xfinity Home (Zigbee Module). I’m now guessing if I should unpair it from ST and go with Xfinity to see if they have that option.
Kind of the only reason I got the smart lock.
This is a change in design philosophy for security devices. It doesn’t look like they are going to add the ability to automate unlocking or change the security mode in the new app. It’s not a missing feature: it’s a change.
If you’re using the Classic app you can setup a Routine to do it.
If you’re using the new app and Scene’s, then you can use the Scene to change the hub Mode and then use a SmartApp like this (if you have access to RBoy Apps) which can run actions when mode changes are detected (it was originally designed to be a Routine’s backup app because Routines very often failed to complete their job) but it can act like a “Routine” for the new ST app:
