ST Routines Randomly Disappearing
Hi, @sdbg
Can you provide the following to check that new routine, please?
See more information about this access here: https://support.smartthings.com/hc/en-us/articles/36170233944852-Enabling-Account-Data-Access-for-Support
  1. Share the name of the new routine.
  2. If different, share the name of the routines that have previously disappeared
Also, based on this, can you confirm if the routine worked normally until you noticed it failed and looked for it in the app?
@nayelyz any update? Should I just try to recreate it from memory? It was pretty complicated, and I’d prefer for it to be restored, with potentially other missing routines I may not know about.
Hi, @Wajo357
Sorry for the delay. I asked the engineering team about this since there are a few other tickets with similar descriptions. Once I get their feedback, I’ll let you know. I’ll keep pinging them
Add me to the list… I keep having my Good Morning routine disappear. So my alarm response goes off every morning. I recreated it twice now. It is very simple… if a certain time of day, a certain single device status, and in Night mode, fire, running a different routine. The one device it relies on is active and the logs show it has regular updates to the hub.
Posting mostly to follow along
Seeing this happen as well in the past 2 weeks. A routine that’s been untouched for a couple of years just disappeared. Added it back, gone the next day. Added again, then a different routine related to the same devices was gone. Seems to be stable right now.
Hi, @Stephen_Johnson, @derekwbeck
Have you checked if the routine appears in any of the following?
  1. The device’s details section, although it doesn’t appear in the Routine’s section
  2. The Advanced Users tool, in the “Rules” section.
Have you checked how many scenes+Routines you have created? We’ve seen this happening for users who have several Routines
It was nowhere to be found. I noticed the first one missing while researching why the lights the lights didn’t turn on when there was motion. Then after recreating that one, researching why they never turned off. The routine for both was there and working earlier in the day. Then gone, recreate, gone again later, repeat.
I have around 40 - 50 routines.
Do you recall the date and time when this incident occurred?
If not, can you create it again? The engineering team can take a look, but they need the following information:
  1. Approximate date and time of when the routine disappeared
  2. Name of the routine
  3. Support access to your account:
I am getting the same problem with disappearing automatic routines. They still appear to be running but I can not longer find them. What the hell is going on with this issue?
Hi, @ULTRA77
Did you notice when they disappeared? having the date and approximate time would help the engineering team investigate the issue.
Have you checked if they appear in my.smartthings.com/Advanced?
Please open support access to your account as instructed below and also share the name of one of those routines:
Hi !…Daily routines loses almost all data in the ST app, displays only one IF condition and one THEN action. all time triggers and actions disappear. Surprisingly actions keep working, if I look for in the Advanced user web interface, the Daily Automation is over there as was created, everything looks okey
, but in ST app, amost all config dissapeared.
Hi, @sdbg, @ULTRA77, @Stephen_Johnson, @derekwbeck, @Wajo357
Following up on this. There was a recent app release, for Android should be 1.8.45 and for iOS, it should be 1.7.45
Can you let me know if the issue remains, please?
