Yes, thanks. Found it. Request is pulled ![]()
Hi @w35l3y
I have a โTuya Zigbee Smart Sprinkler Timerโ for garden irrigation, I installed your โPersonal Tuya Deviceโ driver. It only works partially, it does not detect the percentage of the remaining battery. What can I do?
Thankyou
It can take hours before the battery levels start to report, so give it 24 hours.
I have exactly the same device.
Could not retrieve battery data no matter what i did (dp 11 not working).
I also noticed it was pretty unreliable, unresponsive and then configured it as generic device, under Valves entered โ1โ what got me new tile device of valve. This way it is reliable and stable.
If you figure out battery info let us know.
@Paul_Oliver can you tell us what configuration you are using it with?
I do not have this device. I was just starting that battery reporting can be very delayed in SmartThings. And using the Personal Tuya Driver complicates things.
The Personal Tuya Driver is a driver of last resort and you need to be accepting of its limitations.
Can you please send some logs with CLI. Give it some time and hopefully the Battery percentage will be transmitted. Here are some instructions how to create a log:
@dusanhauko and @brogio , Did you try choosing a different data point for battery ?
Tried 7, 11 and a few others. No luck.
Somewhere I read 14 or 15 worked so may you want to try this also in case you havenโt.
Did you use this with a regular high-pressure line, connected to municipal water service or was it low-pressure from a rain barrel?
I donโt think I can do what youโre asking.
I think I will eventually purchase a dedicated gateway. I tried with the Personal Tuya Device Driver and the interface in the smarthings app is also painful. Furthermore, the connection distance is very short, although I donโt know if this depends on the driver, the gateway or everything together.
OK, Iโll try that. Thanks
I have a zigbee neo siren that uses this driver. However, I canโt change the siren sound with this driver, only thru the settings. Obviously I would like it to sound different when used for a doorbell to a fire alarm. Does anyone know of another driver that allows for this capability?
Hi @w35l3y
This product doesnโt seem to be working.
Device pairing info
| Manufacturer: | _TZE284_aao3yzhs |
| Endpoint 01 application: | 4D |
| Endpoint 01 endpointId: | 01 |
| Endpoint 01 idAsInt: | 1 |
| Endpoint 01 inClusters: | 0004,0005,EF00,0000,ED00 |
| Endpoint 01 initialized: | true |
| Endpoint 01 manufacturer: | _TZE284_aao3yzhs |
| Endpoint 01 model: | TS0601 |
| Endpoint 01 outClusters: | 0019,000A |
| Endpoint 01 profileId: | 0104 |
| Endpoint 01 stage: | 4 |
Summary
dev:1352024-09-03 03:28:44.096 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Tuya check-in message (attribute 0001 reported: 4D)
dev:1352024-09-03 03:28:44.088 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:4913010000180100204DE2FF2038E4FF2000, dni:4913, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:4D, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]] description = read attr - raw: 4913010000180100204DE2FF2038E4FF2000, dni: 4913, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 4DE2FF2038E4FF2000
dev:1352024-09-03 03:28:43.969 PMwarnํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Unprocessed Tuya cluster command: cluster=EF00 command=11 attrId=null value=null data=[00, 09, 76]
dev:1352024-09-03 03:28:43.962 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:catchall: 0104 EF00 01 01 0040 00 4913 01 00 0000 11 01 000976, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4913, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 09, 76]] description = catchall: 0104 EF00 01 01 0040 00 4913 01 00 0000 11 01 000976
dev:1352024-09-03 03:28:43.840 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ NOT PARSED : [raw:49130100000ACFFF214038, dni:4913, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487]
dev:1352024-09-03 03:28:43.835 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:49130100000ACFFF214038, dni:4913, endpoint:01, cluster:0000, size:0A, attrId:FFCF, encoding:21, command:0A, value:3840, clusterInt:0, attrInt:65487] description = read attr - raw: 49130100000ACFFF214038, dni: 4913, endpoint: 01, cluster: 0000, size: 0A, attrId: FFCF, encoding: 21, command: 0A, value: 4038
dev:1352024-09-03 03:28:39.509 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Temperature scale reported by device is: Celsius
dev:1352024-09-03 03:28:39.507 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ dp_id=4 dp=9 fncmd=0 fncmd_len=1 (index=21)
dev:1352024-09-03 03:28:39.504 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ battery_state (0x0E) is 2
dev:1352024-09-03 03:28:39.500 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ dp_id=4 dp=14 fncmd=2 fncmd_len=1 (index=16)
dev:1352024-09-03 03:28:39.495 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ getBatteryPercentageResult: rawValue = 168 โ 84%
dev:1352024-09-03 03:28:39.489 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ dp_id=2 dp=15 fncmd=84 fncmd_len=4 (index=8)
dev:1352024-09-03 03:28:39.478 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ temperature is 27.5 ยฐC
dev:1352024-09-03 03:28:39.460 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ dp_id=2 dp=5 fncmd=275 fncmd_len=4 (index=0)
dev:1352024-09-03 03:28:39.447 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:catchall: 0104 EF00 01 01 0040 00 4913 01 00 0000 02 01 000805020004000001130F020004000000540E040001020904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4913, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 08, 05, 02, 00, 04, 00, 00, 01, 13, 0F, 02, 00, 04, 00, 00, 00, 54, 0E, 04, 00, 01, 02, 09, 04, 00, 01, 00]] description = catchall: 0104 EF00 01 01 0040 00 4913 01 00 0000 02 01 000805020004000001130F020004000000540E040001020904000100
dev:1352024-09-03 03:28:27.881 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ sendZigbeeCommands(cmd=)
dev:1352024-09-03 03:28:27.879 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Debug logging will be turned off after 24 hours
dev:1352024-09-03 03:28:27.852 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Debug logging is true; Description text logging is true
dev:1352024-09-03 03:28:27.849 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Updating ํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE284_aao3yzhs modelGroupPreference = Auto detect (TS0601_Soil_II)
dev:1352024-09-03 03:28:27.380 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:1352024-09-03 03:28:27.375 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:catchall: 0104 0000 01 01 0040 00 4913 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4913, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]] description = catchall: 0104 0000 01 01 0040 00 4913 00 00 0000 04 01 00
dev:1352024-09-03 03:28:27.364 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ NOT PARSED : [raw:491301000068040042105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000, dni:4913, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_aao3yzhs, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:1352024-09-03 03:28:27.350 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:491301000068040042105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000, dni:4913, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_aao3yzhs, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] description = read attr - raw: 491301000068040042105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000, dni: 4913, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000
dev:1352024-09-03 03:28:27.339 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ device announcement
dev:1352024-09-03 03:28:27.333 PMdebugํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ parse() descMap =[raw:catchall: 0000 0013 00 00 0040 00 4913 00 00 0000 00 00 0613495B218FF58F38C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:4913, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[06, 13, 49, 5B, 21, 8F, F5, 8F, 38, C1, A4, 80]] description = catchall: 0000 0013 00 00 0040 00 4913 00 00 0000 00 00 0613495B218FF58F38C1A480
dev:1352024-09-03 03:28:26.783 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ sendZigbeeCommands(cmd=[he raw 0x4913 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x4913 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 299])
dev:1352024-09-03 03:28:26.781 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ initializeDeviceโฆ
dev:1352024-09-03 03:28:26.777 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ configure()โฆ
dev:1352024-09-03 03:26:14.904 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ sendZigbeeCommands(cmd=)
dev:1352024-09-03 03:26:14.902 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Debug logging will be turned off after 24 hours
dev:1352024-09-03 03:26:14.872 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Debug logging is true; Description text logging is true
dev:1352024-09-03 03:26:14.870 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Updating ํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE284_aao3yzhs modelGroupPreference = Auto detect (TS0601_Soil_II)
dev:1352024-09-03 03:26:10.857 PMtraceํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ sendZigbeeCommands(cmd=)
dev:1352024-09-03 03:26:10.854 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Debug logging will be turned off after 24 hours
dev:1352024-09-03 03:26:10.818 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Debug logging is true; Description text logging is true
dev:1352024-09-03 03:26:10.815 PMinfoํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ Updating ํ ์ ์๋ถ์จ๋ ์ธก์ ๊ธฐ (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE284_aao3yzhs modelGroupPreference = Auto detect (TS0601_Soil_II)
dev:1352024-09-03 03:25:20.634 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock Tuya check-in message (attribute 0001 reported: 4D)
dev:1352024-09-03 03:25:20.623 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap =[raw:8515010000180100204DE2FF2038E4FF2001, dni:8515, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:4D, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:01, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]] description = read attr - raw: 8515010000180100204DE2FF2038E4FF2001, dni: 8515, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 4DE2FF2038E4FF2001
dev:1352024-09-03 03:25:16.603 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=)
dev:1352024-09-03 03:25:16.600 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging will be turned off after 24 hours
dev:1352024-09-03 03:25:16.575 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is true; Description text logging is true
dev:1352024-09-03 03:25:16.572 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Updating null (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE284_aao3yzhs modelGroupPreference = Auto detect (TS0601_Soil_II)
dev:1352024-09-03 03:25:16.092 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:1352024-09-03 03:25:16.082 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap =[raw:catchall: 0104 0000 01 01 0040 00 8515 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8515, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]] description = catchall: 0104 0000 01 01 0040 00 8515 00 00 0000 04 01 00
dev:1352024-09-03 03:25:15.773 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:851501000068040042105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000, dni:8515, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_aao3yzhs, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:1352024-09-03 03:25:15.648 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap =[raw:851501000068040042105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000, dni:8515, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE284_aao3yzhs, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:4D, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] description = read attr - raw: 851501000068040042105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000, dni: 8515, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453238345F61616F33797A68730000002003010000204D05000042065453303630310700003003FEFF003000
dev:1352024-09-03 03:25:15.642 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock is present
dev:1352024-09-03 03:25:15.487 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he raw 0x8515 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8515 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 299])
dev:1352024-09-03 03:25:15.481 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock initializeDeviceโฆ
dev:1352024-09-03 03:25:15.442 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock configure()โฆ
dev:1352024-09-03 03:25:15.378 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Statistics were reset. Press F5 to refresh the device page
dev:1352024-09-03 03:25:15.370 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock All Defaults Loaded! F5 to refresh
dev:1352024-09-03 03:25:15.364 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock All child devices DELETED
dev:1352024-09-03 03:25:15.354 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock All States DELETED
dev:1352024-09-03 03:25:15.352 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock Deleted states:
dev:1352024-09-03 03:25:15.341 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock All scheduled jobs DELETED
dev:1352024-09-03 03:25:15.333 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock All current states (attributes) DELETED
dev:1352024-09-03 03:25:15.331 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock Deleted attributes: temperature, checkInterval, humidity, rtt, battery, illuminance, healthStatus, _info,
dev:1352024-09-03 03:25:15.297 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock All settings (preferences) DELETED
dev:1352024-09-03 03:25:15.291 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock Deleted settings: txtEnable (true), logEnable (true), modelGroupPreference (0), advancedOptions (false),
dev:1352024-09-03 03:25:15.265 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock InitializeVars()โฆ fullInit = true
dev:1352024-09-03 03:25:15.247 PM
- According to the logs, you are not using my driver.
- My driver doesnโt have this device pre-programmed.
- If you want to use my driver, then you will need to specify the datapoints in the settings by yourself.
- In this case, please read the first post of this thread for more details.
