Install CLI on your computer:
• You have to download from this link lastet release of the compressed file smartthings-win.zip, if you use windows or the one necessary for your operating system
• In that link you also have installation help, use and all the commands you can use
• Unzip it and move the smartthings.exe file to a folder on your computer from where it will be used. for example to a new folder in documents/CLI
• You have to open the windows powerShell terminal window and you have to go to the directory (folder) where the smarttings.exe file is.
• Use the DOS commands “cd…” to move down directory and “cd directory name” to move to that directory. This is an example of my folder for CLI or VSC folder
• the first time you type a CLI command it will take you to the smartthing page to authorize your account.
• type .\smartthings edge:drivers:logcat
• enter the IP of your HUB, you can see it in IDE
• It will show you the list of drivers installed on your HUB
• type the number corresponding to the driver you want to see
• It will show you the activity of the device connected to that driver
