[ST Edge] Personal Tuya Devices - Generic EF00 Device
What did you mean exactly?
Here is the docs about custom capabilities…
@w35l3y,
I just bought a Tuya presence sensor, and I don’t believe it is included yet in your driver. Can you check?
Hello
I bought irrigation valve from Aliexp…
Is there any way to improve support for it? Works on/off, but battery and else does not show.
See screenshot.
Regards
Dusan
The following DP (Data Points) are relevant for you product
Battery percentage in DP 11 .
Try to change profile to irrigator and select the relevant DP’s
Thanks for quick reply but DP 11 does not work.
What else remains?
Would i have use of other DPs and charasterics of irrigation valve with your driver if configured properly or just on/off and battery?
Tnx :sweat_smile:
Regarding the battery, give it some time until reported.
Regarding other DP’s you will need to modify @w35l3y driver to include them. @w35l3y gave some instructions how to modify.
hi there , someone told me to ask you to add the finger print of my device to your driver , I used your driver for smoke detector and it works well but without battery read , here is my device
Manufacturer: _TZE200_t5p1vj8r
Model: TS0601
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x53
ZCL Version: 0x03
Network ID: 0xD4CA
Zigbee EUI: 5C0272FFFEC4BE19
Device ID: fc373bbd-cf7b-4b41-b632-5dd00206f359
Server Cluster:
Ep: 0x01={ 0000,0004,0005,EF00 }
Client Clusters:
Ep: 0x01={ 0019,000A }
Signal Metrics:
LQI: 188 … RSSI: -52 dbm
Best Regards
These are the data points (DP) for your device
Try to adjust the battery DP to 15 in the device settings.
the battery of this device in tuya doesnt show percentage , it only show if battery low or high , this is link from z2m
According to my understanding battery level should be also displayed on from DP15 and the state (high , medium , low) is displayed from DP14.
You are probably referring to different device like _TZE200_ntcy3xu1 (please note TS0601_smoke_1 in the link you provide) that only have battery low DP.
DP14 done the trick , many thanks @dotan_shai , but it shows the battery 100% , as i remember from zigbee2mqtt it wasnt percentage , it was only battery state high low as you mentioned
is it possible to get rid of debug info ?
That’s not a driver problem, that’s a SmartThings problem. They made some changes and broke the ability to show HTML properly. It doesn’t affect functionality, just appearance.
ETA: This affects the iOS app too, not just Android.
Hello. Could you provide datapoints to this device?
Go into settings and change the Profile to generic then normal and then choose Thermostat. Then you many not need to worry about the data points.
In case you’ll need it, these are the DP’s for _TZE204_p3lqqy2r Touch thermostat 16A 2.0
Thanks guys. If I want to use all functions and set the DP, nothing changes at the device screen… Suggestions?
Got it. Possible to add DP for an new thermostat profile to get all values? Cheers
Yes, you can create a custom profile , test in your hub and send a Pull Request to @w35l3y Github.
@w35l3y gave some instructions regarding how to do it in his github , here:
You’ll need some coding experience.
