Hi everyone, after connecting tuya app to smartthings no devices (three smart plug) appear even though I have supported smart sockets from Aliexpress. Integration from Smart Life app works but Tuya app not working. Thanks
So the SmartLife app is showing that the devices have a SmartThings integration, but they are not showing up in SmartThings. And you are using the Tuya integration. Correct?
I personally have 4 Tuya Wi-Fi breakers that show as having a SmartThings integration but don’t show up in SmartThings.
So a couple of things:
You could try the SmartLife integration instead of the Tuya integration and see if it works any better.
You can refresh the Tuya integration in SmartThings and see if that works. Go to Menu tab in lower right corner > gear in upper right corner > Linked Services > Tuya > Refresh in lower left corner.
If the above fail: The integration is owned and maintained by Tuya, so you should contact them.
And if all else fails you can try the following work around
If you haven’t found a working solution yet, here’s what I managed to scrape together after too much time spent on the Tap-To-Run method and other stuff.
