SmartApps Smart lighting stopped working
I’ve been using smart lighting for years to automate some simple stuff like having lights turn on and off based off of motion.
In the past week or so it started to not work very well and in the past 2 days I’ve noticed that it’s just straight up does not work.
If I go look at my smart lighting the setup is still perfect. If I look at the motion sensor I can see motion is detected and the lights are just not turning on.
Anyone else seeing this behavior?
Any ideas?
Funny story, the lights just turned on, 5 minutes late. It says motion was detected 5 minutes.
I have to have been using the Smart Lighting feature for basic lighting needs. Mine is and has been working well with no issues.
SmartLighting is most certainly NOT working. If you think that it is working it is because previously entered SL routines are still running… but try and edit an existing routine or add a new one and you will see the problem.
The SL app sits a spins forever.
I just did a minor edit (changed the end time) of one of my Smart lighting routines. It seems to have saved no problem.
Does location matter? I’m in Canada.
The SL ‘app’ seems to be working fine for me (Android app, UK) and it allowed me to create a rule which worked correctly. I thought it was perhaps spinning a little more than I recall, but I haven’t used it for a while.
Smart lighting has not worked properly for me in the US for several months.
  1. I can’t open, create or edit anything
  2. automations continue to run
  3. I can enabled, disable, and delete using the AWA.
Ditto that behavior here.
Hmm, it’s working for me in Canada, and @orangebucket in the UK, but not @Paul_Oliver in the US. Are we sure this isn’t an anti-tariff plot by someone? :wink:
But seriously, I just successfully created and saved a new SL routine in my SmartThings for Android. It should run tonight. I’ll check the light history in the morning to see if it turned it on and off and report back.
I’m in the U.S. and SL is working just fine.
Well, my test smart lighting routine ran fine last night. So adding a new routine and executing it seems to work fine.
I went old school and unplugged my SmartThings Hub and plugged it back in and now everything is working fine.
“Have you tried turning it off and on again” - somehow, it’s always the right answer
Nope - I wouldn’t mark the turn it off and turn it back on again as a solution. It most definitely does not solve my problem. Like I said, I haven’t been able to edit or add a smart lighting routine for months, but the ones that exist work fine.
I’m in the US (west coast) in case it’s location based.
I’m having this problem also. The smart lighting routines are running fine but when I try to edit or create a new one I just get the four spinning dots. It was doing it when I was running Android 14 and it is still doing it now that I updated to Android 15 on my Samsung S23 Ultra and Samsung Tab 10 Ultra. I tried clearing the cache but that did not help.
Hi, @uberrob, @DOWNSOUTH407
Can you let us know which OS (Android/iOS) and version of the SmartThings app you’re using, please?
Also, please help us collect new evidence of this issue:
  1. A screen recording of you trying to enter the SmartLighting app, showing how it stays loading
    • Note: If you’re using iOS, please enable the “troubleshooting” option as mentioned below
  2. Collect the app logs after replicating the issue as follows:
–For Android–
  1. Go to Menu > Gear Icon > About SmartThings
  2. Tap the SmartThings logo 10 times.
  3. This will open the developer’s space > tap ‘report a problem’
  4. This will send you to the report page. Select a frequency and write a short description of the issue.
  5. Click on “Report” and a log file will be generated for you to send over email, please do to build@smartthings.com
–For iOS–
First:
  1. Enable the creation of additional logs in the app:
  1. In the ST app, go to “menu” > “settings”.
  2. At the bottom of that page, you’ll find a section called “Troubleshooting”. Please, enable the option that says “Create Additional SmartThings Log”.
  3. Restart the app
    Then:
  1. In the app menu, go to “contact us”
  2. Then, tap on “Error reports”
  3. On the opened page, tap 10 times on the title/label “What is the error about?” or until the prompt to create a log appears.
  4. Click on “ok” and wait for the process to finish. Then, save the generated file in the place you prefer and share it with us at build@smartthings.com
Has there been an resolution to this issue? I have two locations, one has 3 hubs: V3, V2 and a SmartThings Station. I’ve powered them off (for over 30 minutes), reset my phone running (1.8.34.21), etc. Just spinning icon when I try to add a Smart Lighting routine. I have a second location with just a V3 hub, when I try that location… boom right into adding a routine. Back at my primary location: I’ve tried powering off my V2 and SmartThings Station and just using my V3, since the devices I want to control are on the V3, but same result… just a spinning icon. Tried my old Note8 that runs an older version of ST’s (1.8.07.23), same thing just spinning when I try to create a routine.
Do you have any devices disabled / hidden in the affected location?
If so, enable / show all devices and see if it helps.
Well, that was a good idea, but it didn’t help. I did have about 20 devices hidden. Put them back and rebooted my hubs after leaving them off for over 30 minutes. Still just a spinner when I try to add a Smart Lighting routine.
I have 2 US locations with 4 hubs and Smart lighting has not worked for months. No hidden devices at either location.
Hi, @ericreed5280
We’re pushing this investigation again, we were hoping you could help us collect some info for this, please:
  1. Replicate the issue of opening the SL app and confirm it doesn’t load
  2. Get the app logs within 1 minute after this test since the logs only include 2-3 minutes before you get them
Instructions for Android
  1. Take a note of the date and time of the test to look for this event in the Cloud logs.
  2. Finally, provide support access to your account to see more details of your service of SL
  3. Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM.
  4. Enable support access to your account:
More info about this access here: https://support.smartthings.com/hc/en-us/articles/36170233944852-Enabling-Account-Data-Access-for-Support
I also requested this info from @Paul_Oliver. Thank you both for the help
