Schlage Nexia Lock Remote Administration
Not possible with my Schlage599IR. Gave up for Lockstate lock.
ANYONE - Just wanted to know if there is an update on the ability to do Remote Administration on Schlage Locks. I get the notification and alarms - BUT WHAT about Availability to change, add and delete PIN numbers.
Collin
Leave this here: [Depricated] Lock Code Manager and (Enhanced) Z-Wave Schlage Touchscreen Lock
Really ? I have to get into Downloading IDE’s and Cut and Pasting Code?
Shouldn’t Schlage Locks be automatically supported?
I am extremely Skeptical
Schlage locks are “supported” using the standard Device Type. No cutting and pasting required. However, you will not be able to add, view, delete User Codes. Only lock/unlock and see status.
If you want to get better programming options, use this:
That will let you turn Auto Lock on/off, turn Lock and Leave on/off, set Alarm Sensitivity, and query status and battery life.
If you want to set, delete, view User Codes, use this:
-Rob
@pickerin Rob if you’ve installed the User Lock Mgmt SmartApp:
You could also use the corresponding SmartDevice I’ve written for Schlage locks:
This would allow you use the Invalid Codes notifications with the User Management App and also use another SmartApp I’ve written to change the Schlage Lock sensitivity and alarm setting automatically when the mode changes (e.g. Alert while Home, Tamper while away) and use the Alarm on the lock as a proxy for a motion sensor (ie. it reports motion when the alarm is set off).
The IDE is really just a website. The ability to create custom code is one of the advantages of smartthings. Its a great way to keep the price down, and allow massive support of devices.
Nexia is a great example, hardware costs about the same, but monthly subscription. I am sure smartthings can support way more devices and add a ton of features if everyone was willing to pay $10 a month.
I agree though that I would like them to promote home grown solutions into their repository so it makes it easy to add more devices.
@bluminicoop, what did you wind up going with for the Schlage Lock controls if it was not the SmartThings hub.
I am using SmartThings for thermostats and Nexia for the locks (SmartThings hub can go below 55 degrees while nexia cannot. Would love to know what you wound up going with
I gave up on Schlage and any lock interface with ST. I love my LOCKSTATE lock. I have 6. One on my home. 4 short term rentals and my business. Best functionality for my needs. So I have nest, LOCKSTATE and ST to deal with. It would be great if they could play together but not the end of the world. Hope this helps.
This definitely helps, but are you using SmartThings to run the locks you purchased or one of the other?
I use ST for doors, window and motion. I have rentals and like knowing when doors are open. Especially sliders. If left open in the rain I could have big issues. The motion has come in handy a couple of times as well. None of my locks or thermostats are connected to ST.
Thank you for this update Karen, very helpful and will look into Lockstate for future, unfortunately I have so many Schlage locks onsite already that it may not be viable to swap at this point : (
I know this is an older post but I still wanted to add my comments here. I just connected my BE369 to my Smartthings hub and it paired just fine. It works well reading the battery level and locking / unlocking, of course, you have to turn the dead bolt manually. On a side note, I had this lock installed for 8+ years. I recently got a red light on the Schlage button which indicates low battery. As I took of the inner cover and removed the battery tray that holds the three AA batteries, unfortunately it came out in pieces. The door faces the hot SW Florida sun and I guess that did it in. I called Schlage to see if I could get a battery tray and they said they didn’t have that part and offered to send me a complete new BE369!
I wanted to be able to program lock codes from the Smartthings app but did not see the area right away. It shows when you are on the main page in the Home Solutions area. Once you click Smart Locks there, you can see the add / delete codes section.
