Samsung Washer won't connect
Hi There, few months back I installed a new Samsung washer at home. I set it up in SmartThing App using the home 2.4G WiFi network.
Everything was fine until last week, when the washer disappeared from SmartThing App.
I tried to re-install the washer but it does not work.
My steps are:
  • Set AP to 2.4GHz only, WPA2
  • Set Mobile to same 2.4GHz WiFi network
  • Add washer to SmartThing App via QR Code scan
  • Set Washer in AP mode
  • Washer is detected in SmartThing App
  • On Mobile I switch to washer’s own WiFi network
  • Authenticate using the default password
  • I Indicate the 2.4GHz WiFi Network to connect
  • I input the WiFI password
  • The SmartThing App start the registering
  • After about 1minute the Washer display “Cannot Connect”
  • The App show Error code: 15-200
Anyone can help me to troubleshoot the matter?
Try resetting the washer… reboot your router before adding
Already tried. Does not work.
I can only offer suggestions because their WiFi on their appliances has it’s quirks. Every person seems to find different tricks to get it to work.
  • SSID is not hidden
  • SSID name and password contain no spaces
  • probably a few other things I am forgetting
contact ST support for appliances and post on the Samsung Community forum as you might get lucky but they will probably direct you back to this forum :man_shrugging:
