@Mike_Maxwell - I just bypassed the verizon router today at my friends house. Internet still works, TV still works, guide still works, VOD still works.
In this case the ONT had both ethernet and coaxial ran to the router.
1. Login to your fios router, release the ip address provided by verizon. <-- Most important part.
2. Turn off the fios router, turn off your regular router.
3. Unplug ethernet from fios wan and plug into your router wan port.
4. Turn on your regular router, let it get an IP address from verzion.
5. Connect the fios wan port to your routers WAN port.
6. turn on the fios router, wait for it to get an internet connection.
7. See if your guide, vod works, it should
Speeds under 100 use coax from ONT. @Mike_Maxwell pull the trigger and upgrade to 150. They will swap the connection to ethernet and upgrade your equipment
Ok, only coax comming in for me, which splits to the house distro, the router and what appears to be a moca adapter in its own right. This box then feeds ethernet to the router want port. So I canāt figure just wth this setup is doingā¦
And you say moca to even the tech savy and their eyes glaze overā¦
I have moca adaptors in every room. I made the mistake of declining CAT5 when we built the house. And after fiasco experience with powerline adaptors, moca was the savior.
Ha, ha, ha⦠I thought the āfew weeksā has been replaced by ānote I am not disclosing any timelinesā. Thereās been a week or two since April, any more news, yet? lolā¦
Just purchased a Samsung S8. It has the Connect app preloaded bit I installed the ST app so I could use that. When trying to log on to the older ST app, it requires the hub to be reset and therefor wiping out everything. I was hoping it would log into ST like on my Samsung S5. What a PITA! Luckily I donāt have a big system with tons of smart things but this should be a simpler process. I might as well just use the Connect app once I get everything reloaded.
I opened the older ST app yesterday after a few days of doing nothing to it. I didnāt reset my hub. Opening the older ST app on my new Samsung S8 works just like on my Samsung S5. Itās odd because it wanted me to do a hub reset when I 1st tried using the ST app on this new phone.
Now my question to add is, is it worth resetting the hub and start using the new Samsung Connect app instead of just using the ST app on my S8? How is the user experience from people that have used both?
Hi, I have a Samsung UE55MU6100KXXU TV, and a SmartThings Hub and Google Home, Iāve been playing around with getting Google Home to turn on and off my TV, and itās a bit flaky, and Iāve noticed something in the Samsung Connect App as well, which might indicate itās not a SmartThings issue.
Once the TV has been off for a few minutes, a power button shows up beside the TV when looking at the list of devices in Samsung Connect (it isnāt there at first after you turn it off).
If you press this power button to turn on the TV, it never works, but if you go into the device, you can press the virtual remoteās button to turn on the TV, and that does work.
So I wonder are these 2 different commands to turn on the TV, and maybe this behaviour that causes the button to be there or not be there depending on how long since the TV was turned off is messing up the SmartThings integration?
p.s. apologies, I have screenshots of the button not there, and the remote screen, but I can only put one picture in the post, as Iām a new user
Its been launched. It is official and yet you basically have to make a choice Connect or Smartthings. Oh yeah then choose between Actiontiles or Smarttiles⦠meanwhile my Family Hub 2.0, oven washer/dryer only want to talk to certain devices. I refuse to factory default my smartthings hub a 3rd time until I know my z-wave devices will not all have to be re-added and hours of integrating all my automation apps etc.
tgauchat
62
Which did you choose?
SmartTiles is no longer available for installation; but ActionTiles is. And, yes, to use ActionTiles you must choose the āSmartThings Appā option. Personally, I still am in the dark if there is any way to concurrently run āConnectā and āSmartThings Appā, but I see lots of notes implying it isnāt possible ⦠or maybe you have to do ST first, then Connect?
And then there are some issues related to using a Samsung Account vs purely a SmartThings Account? And if youāre in Asia-Pacific / Australia, beware, you may land on new āunofficialā Shard AP02 which is incomplete and currently does not run ActionTilesā¦
Lot of confusion out there that could be solved with some pretty simple coordinated communication from Samsung + SmartThings ⦠I think.
