Questions about to Publish Request
Long time no see!
@erickv @nayelyz
Before the final deployment, I want to make a Publish Request after making preparations.
We have received a reply that it will take about 15 days after the request.
Q1) I wonder why it takes exactly 15 days. It wouldn’t take that long for a simple distribution approval.
Is it because the test runs for 15 days?
Q2) If the Publish Reqeust is approved, will our service be published as smartThings immediately?
In fact, we need to consider the timing of the release, so even after approval, we want to make a decision on the right time. (after request is approved, click the button … etc)
For that reason, I thought the following process would take place.
(Publish Request → Comfirm → Publish) Is this process possible?
Hey @Maxwell_Kim
I’m glad you still around.
The resolution time you mention is for Hub-Connected Integrations. For your ST Schema integration, it’ll take a minimum of 2 business days, which may vary depending on the current certification queue.
As for the availability of your product at the SmartThings App, yes, it is the expected behavior for ST Schema compatible integrations. However, as soon as you submit your integration, our team will contact you to address these details.
@erickv
Hi erick! This is Maxwell.
Finally, I did Publish Request. (via another account a.k.a kdnavien.iot)
But! It’s already been about a week since publish request.
My boss is so curious about the exact service for publish schedule. (please help me!)
Is the review going well? I’m curious about that too.
When can I expect end date?
Thank you!
Hey @Maxwell_Kim
It’s good to hear you’re doing good!
I’ve tracked some updates about your request and it seems that our Certification Team has contacted you this morning. Check your inbox to continue with your device certification, and if you haven’t received any notification, please let me know.
