I used this handler:
metadata {
definition (name: “GreenWave”, namespace: “greenwave”, author: “Micha”) {
capability “Switch”
capability “Energy Meter”
capability “Power Meter”
capability “Refresh”
capability “Configuration”
capability “Actuator”
capability “Sensor”
command "reset"
(1..6).each { n ->
attribute "switch$n", "enum", ["on", "off"]
attribute "power$n", "number"
attribute "energy$n", "number"
command "on$n"
command "off$n"
command "reset$n"
fingerprint deviceId: "0x1001", inClusters: "0x25,0x32,0x27,0x70,0x85,0x72,0x86,0x60", outClusters: "0x82"
// simulator metadata
simulator {
status “on”: “command: 2003, payload: FF”
status “off”: “command: 2003, payload: 00”
status “switch1 on”: “command: 600D, payload: 01 00 25 03 FF”
status “switch1 off”: “command: 600D, payload: 01 00 25 03 00”
status “switch6 on”: “command: 600D, payload: 06 00 25 03 FF”
status “switch6 off”: “command: 600D, payload: 06 00 25 03 00”
status “power”: new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: 30, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
status “energy”: new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: 200, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
status “power1”: “command: 600D, payload: 0100” + new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: 30, precision: 3, meterType: 4, scale: 2, size: 4).format()
status “energy2”: “command: 600D, payload: 0200” + new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: 200, precision: 3, meterType: 0, scale: 0, size: 4).format()
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile(“switch”, “device.switch”, width: 2, height: 2, canChangeIcon: true) {
state “on”, label: ‘${name}’, action: “switch.off”, icon: “st.switches.switch.on”, backgroundColor: “#79b821”
state “off”, label: ‘${name}’, action: “switch.on”, icon: “st.switches.switch.off”, backgroundColor: “#ffffff”
valueTile(“power”, “device.power”, decoration: “flat”) {
state “default”, label:‘${currentValue} W’
valueTile(“energy”, “device.energy”, decoration: “flat”) {
state “default”, label:‘${currentValue} kWh’
standardTile(“reset”, “device.energy”, inactiveLabel: false, decoration: “flat”) {
state “default”, label:‘reset kWh’, action:“reset”
standardTile(“refresh”, “device.power”, inactiveLabel: false, decoration: “flat”) {
state “default”, label:‘’, action:“refresh.refresh”, icon:“st.secondary.refresh”
standardTile(“switch1”, “switch1”, width: 2, height: 2, canChangeIcon: true) {
state “on”, label: ‘${name}’, action: “switch1.off”, icon: “st.switches.switch.on”, backgroundColor: “#79b821”
state “off”, label: ‘${name}’, action: “switch1.on”, icon: “st.switches.switch.off”, backgroundColor: “#ffffff”
/*(1..6).each { n ->
standardTile("switch$n", "switch$n", canChangeIcon: true) {
state "off", label: '${name}', action: "on$n", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
state "on", label: '${name}', action: "off$n", icon: "st.switches.switch.on", backgroundColor: "#79b821"
valueTile("power$n", "power$n", decoration: "flat") {
state "default", label:'${currentValue} W'
valueTile("energy$n", "energy$n", decoration: "flat") {
state "default", label:'${currentValue} kWh'
main([“switch”, “power”, “energy”, “switch1”, “switch2”, “switch3”, “switch4”, “switch5”, “switch6”])
details([“switch”,“power”,“energy”,
“switch1”,“power1”,“energy1”,
“switch2”,“power2”,“energy2”,
“switch3”,“power3”,“energy3”,
“switch4”,“power4”,“energy4”,
“switch5”,“power5”,“energy5”,
“switch6”,“power6”,“energy6”,
“refresh”,“reset”])
def result = null
if (description.startsWith(“Err”)) {
result = createEvent(descriptionText:description, isStateChange:true)
} else if (description != “updated”) {
def cmd = zwave.parse(description, [0x60: 3, 0x32: 3, 0x25: 1, 0x20: 1])
if (cmd) {
result = zwaveEvent(cmd, null)
log.debug “parsed ‘${description}’ to ${result.inspect()}”
result
def endpointEvent(endpoint, map) {
if (endpoint) {
map.name = map.name + endpoint.toString()
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd, ep) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x32: 3, 0x25: 1, 0x20: 1])
if (encapsulatedCommand) {
if (encapsulatedCommand.commandClassId == 0x32) {
// Metered outlets are numbered differently than switches
Integer endpoint = cmd.sourceEndPoint
if (endpoint > 2) {
zwaveEvent(encapsulatedCommand, endpoint - 2)
} else if (endpoint == 0) {
zwaveEvent(encapsulatedCommand, 0)
} else {
log.debug(“Ignoring metered outlet $endpoint msg: $encapsulatedCommand”)
} else {
zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd, endpoint) {
def map = [name: “switch”, type: “physical”, value: (cmd.value ? “on” : “off”)]
def events = [endpointEvent(endpoint, map)]
def cmds =
if (endpoint) {
cmds += delayBetween([2,0].collect { s → encap(zwave.meterV3.meterGet(scale: s), endpoint) }, 1000)
if(endpoint < 4) cmds += [“delay 1500”, encap(zwave.basicV1.basicGet(), endpoint + 1)]
} else if (events[0].isStateChange) {
events += (1…4).collect { ep → endpointEvent(ep, map.clone()) }
cmds << “delay 3000”
cmds += delayBetween((0…4).collect { ep → encap(zwave.meterV3.meterGet(scale: 2), ep) }, 800)
if(cmds) events << response(cmds)
events
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd, endpoint) {
def map = [name: “switch”, value: (cmd.value ? “on” : “off”)]
def cmds =
if (!endpoint && events[0].isStateChange) {
cmds += delayBetween((1…4).collect { ep → encap(zwave.meterV3.meterGet(scale: 2), ep) })
events
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd, ep) {
def event = [:]
def cmds =
if (cmd.scale < 2) {
def val = Math.round(cmd.scaledMeterValue*100)/100.0
event = endpointEvent(ep, [name: “energy”, value: val, unit: [“kWh”, “kVAh”][cmd.scale]])
} else {
event = endpointEvent(ep, [name: “power”, value: Math.round(cmd.scaledMeterValue), unit: “W”])
if (!ep && event.isStateChange && event.name == “energy”) {
// Total strip energy consumption changed, check individual outlets
(1…4).each { endpoint →
cmds << encap(zwave.meterV2.meterGet(scale: 0), endpoint)
cmds << “delay 400”
cmds ? [event, response(cmds)] : event
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd, ep) {
updateDataValue(“MSR”, String.format(“%04X-%04X-%04X”, cmd.manufacturerId, cmd.productTypeId, cmd.productId))
null
def zwaveEvent(physicalgraph.zwave.Command cmd, ep) {
log.debug “${device.displayName}: Unhandled ${cmd}” + (ep ? " from endpoint $ep" : “”)
def onOffCmd(value, endpoint = null) {
encap(zwave.basicV1.basicSet(value: value), endpoint),
“delay 500”,
encap(zwave.switchBinaryV1.switchBinaryGet(), endpoint),
“delay 3000”,
encap(zwave.meterV3.meterGet(scale: 2), endpoint)
def on() { onOffCmd(0xFF) }
def off() { onOffCmd(0x0) }
def on1() { onOffCmd(0xFF, 1) }
def on2() { onOffCmd(0xFF, 2) }
def on3() { onOffCmd(0xFF, 3) }
def on4() { onOffCmd(0xFF, 4) }
def on5() { onOffCmd(0xFF, 5) }
def on6() { onOffCmd(0xFF, 6) }
def off1() { onOffCmd(0x0, 1) }
def off2() { onOffCmd(0x0, 2) }
def off3() { onOffCmd(0x0, 3) }
def off4() { onOffCmd(0x0, 4) }
def off5() { onOffCmd(0x0, 5) }
def off6() { onOffCmd(0x0, 6) }
def refresh() {
delayBetween([
zwave.basicV1.basicGet().format(),
zwave.meterV3.meterGet(scale: 0).format(),
zwave.meterV3.meterGet(scale: 2).format(),
encap(zwave.basicV1.basicGet(), 1) // further gets are sent from the basic report handler
def resetCmd(endpoint = null) {
delayBetween([
encap(zwave.meterV2.meterReset(), endpoint),
def reset() {
delayBetween([resetCmd(null), reset1(), reset2(), reset3(), reset4(), reset5(), reset6()])
def reset1() { resetCmd(1) }
def reset2() { resetCmd(2) }
def reset3() { resetCmd(3) }
def reset4() { resetCmd(4) }
def reset5() { resetCmd(5) }
def reset6() { resetCmd(6) }
def configure() {
def cmds = [
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, configurationValue: [0, 0, 0, 1]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, configurationValue: [0, 0, 0x79, 0]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 90).format(),
[5, 8, 9, 10, 11].each { p →
cmds << zwave.configurationV1.configurationSet(parameterNumber: p, size: 2, scaledConfigurationValue: 5).format()
[12, 15, 16, 17, 18].each { p →
cmds << zwave.configurationV1.configurationSet(parameterNumber: p, size: 1, scaledConfigurationValue: 50).format()
cmds += [
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 15*60).format(),
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, configurationValue: [1]).format(),
delayBetween(cmds) + “delay 5000” + refresh()
private encap(cmd, endpoint) {
if (endpoint) {
if (cmd.commandClassId == 0x32) {
if (endpoint < 0x80) {
endpoint += 2
} else {
endpoint = ((endpoint & 0x7F) << 2) | 0x80
zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:endpoint).encapsulate(cmd).format()
} else {
cmd.format()
And created virtual switches for the 6 nodes with this smartapp:
[[RELEASE] Virtual / Physical Switch Sync]
