SmartPower Outlet - Show Watts on 'My Home>>Things page instead of "On"/"Off"
Hi all - I have a couple SmartPower Outlets that I have my entertainment systems connected through. I like to see the wattage used. I really don’t want a user to be able to turn the device on or off… instead on mthe main “My Home”>>“Things” page I would like to have the device handler show wattage used currently instead of the on/off status. Any ideas on how to easily do that? Thanks for any suggestions.
You’ll have to put together your own DTH that tells ST the “main” tile is power. This is very easy to do, so I put one together for you based on ST’s own DTH:
https://raw.githubusercontent.com/constjs/jcdevhandlers/master/devicetypes/jscgs350/my-smartpower-outlet.src/my-smartpower-outlet.groovy
You know how long I’ve been meaning to do this? And am just too darn lazy?
You’re making it worse!
Thank you though!
Wow. Perfect. Thanks so much!
Here’s the Iris version based of @blebson so you get the additional power info and settings:
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *	SmartPower Outlet (CentraLite)
 *	Author: SmartThings
 *	Date: 2015-08-23
metadata {
	// Automatically generated. Make future change here.
	definition (name: "Iris Smart Plug", namespace: "blebson", author: "SmartThings") {
		capability "Actuator"
		capability "Switch"
		capability "Power Meter"
		capability "Energy Meter"
		capability "Configuration"
		capability "Refresh"
		capability "Sensor"
        capability "Health Check"
		capability "Light"
		capability "Outlet"
		// indicates that device keeps track of heartbeat (in state.heartbeat)
		attribute "heartbeat", "string"
		attribute "timerStart", "number"
		attribute "energyDisplay", "string"
		attribute "elapsedTimeDisplay", "string"
		command "resetEnergyUsage"
		fingerprint profileId: "0104", inClusters: "0000 0003 0004 0005 0006 0B04 0B05 FC03", outClusters: "0019", manufacturer: "CentraLite",  model: "3210-L", deviceJoinName: "Outlet"
		//fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0B04,0B05", outClusters: "0019", manufacturer: "CentraLite",  model: "3200", deviceJoinName: "Outlet"
		//fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0B04,0B05", outClusters: "0019", manufacturer: "CentraLite",  model: "3200-Sgb", deviceJoinName: "Outlet"
		//fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0B04,0B05", outClusters: "0019", manufacturer: "CentraLite",  model: "4257050-RZHAC", deviceJoinName: "Outlet"
	// simulator metadata
	simulator {
		// status messages
		status "on": "on/off: 1"
		status "off": "on/off: 0"
		// reply messages
		reply "zcl on-off on": "on/off: 1"
		reply "zcl on-off off": "on/off: 0"
	preferences {
		section {
			image(name: 'educationalcontent', multiple: true, images: [
				"http://cdn.device-gse.smartthings.com/Outlet/US/OutletUS1.jpg",
				"http://cdn.device-gse.smartthings.com/Outlet/US/OutletUS2.jpg"
        section("Reporting Intervals") {
        	input "intervalMin", "number", title: "Minimum interval between reports [s]", defaultValue: 5, range: "1..600"
        	input "intervalMax", "number", title: "Maximum interval between reports [s]", defaultValue: 600, range: "1..600"
	// UI tile definitions
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00A0DC", nextState: "turningOff"
				attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState: "turningOn"
				attributeState "turningOn", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00A0DC", nextState: "turningOff"
				attributeState "turningOff", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState: "turningOn"
			tileAttribute ("power", key: "SECONDARY_CONTROL") {
				attributeState "power", label:'${currentValue} W'
		valueTile("energyDisplay", "device.energyDisplay", width: 5, height: 1, decoration: "flat") {
			state "default", label:'Energy used: ${currentValue}', unit: "kWh"
		standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 1, height: 1) {
			state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
		standardTile("resetUsage", "command.resetEnergyUsage", decoration: "flat", width: 1, height: 1){
			state "default", action: "resetEnergyUsage", label:'Reset kWh', icon:"st.Health & Wellness.health7"
		valueTile("elapsedTimeDisplay", "device.elapsedTimeDisplay", decoration: "flat", width: 5, height: 1){
			state "default", label: 'Time: ${currentValue}', unit: "h"
		standardTile("configure", "device.switch", inactiveLabel: false, decoration: "flat", width: 1, height: 1) {
			state "default", label:"", action:"configure", icon:"st.secondary.configure"
		standardTile("power", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "power", label: '${currentValue} W', icon: "st.secondary.activity"
		main "power"
		details(["switch","energyDisplay","resetUsage","elapsedTimeDisplay","refresh"])
// Parse incoming device messages to generate events
	log.debug "description is $description"
	// save heartbeat (i.e. last time we got a message from device)
	state.heartbeat = Calendar.getInstance().getTimeInMillis()
	if (state.timerStart == null)
		state.timerStart = Calendar.getInstance().getTimeInMillis()
		state.energy = 0.0
	def finalResult = zigbee.getKnownDescription(description)
	//TODO: Remove this after getKnownDescription can parse it automatically
	if (!finalResult && description!="updated")
		finalResult = getPowerDescription(zigbee.parseDescriptionAsMap(description))
	if (finalResult) {
		log.info finalResult
		if (finalResult.type == "update") {
			log.info "$device updates: ${finalResult.value}"
		else if (finalResult.type == "power") {
			def powerValue = (finalResult.value as Integer)/10
			sendEvent(name: "power", value: powerValue, isStateChange: true, displayed: false) // note: stateChange = true added so the energy calculation can work properly
				Dividing by 10 as the Divisor is 10000 and unit is kW for the device. AttrId: 0302 and 0300. Simplifying to 10
				power level is an integer. The exact power level with correct units needs to be handled in the device type
				to account for the different Divisor value (AttrId: 0302) and POWER Unit (AttrId: 0300). CLUSTER for simple metering is 0702
			calculateAndShowEnergy()
		else {
			sendEvent(name: finalResult.type, value: finalResult.value)
	else {
		log.warn "DID NOT PARSE MESSAGE for description : $description"
		log.debug zigbee.parseDescriptionAsMap(description)
def calculateAndShowEnergy()
    def recentEvents = device.statesSince("power", new Date()-1, [max: 2]).collect {[value: it.value as float, date: it.date]}
    def deltaT = (recentEvents[0].date.getTime() - recentEvents[1].date.getTime()) // time since last "power" event in milliseconds
    deltaT = deltaT / 3600000 // convert to hours
    def energyValue = device.currentValue("energy")
    if(energyValue != null) {
    	energyValue += (recentEvents[1].value * deltaT) / 1000 // energy used since last "power" event in kWh
    sendEvent(name: "energy", value: energyValue, displayed: false)
    sendEvent(name: "energyDisplay", value: String.format("%6.3f kWh",energyValue), displayed: false)
    def currentTime = Calendar.getInstance().getTimeInMillis()
    def timeDifference = ((long)currentTime - state.timerStart)/1000; // in seconds
    int h = (int) (timeDifference / (3600));
    int m = (int) ((timeDifference - (h * 3600)) / 60);
    int s = (int) (timeDifference - (h * 3600) - m * 60);
    int d = (int) h >= 24 ? h / 24 : 0
    h = d > 0 ? h % 24 : h
    sendEvent(name: "elapsedTimeDisplay", value: String.format("%dd %02d:%02d:%02d", d, h, m, s), displayed: false)
def off() {
	zigbee.off()
def on() {
	zigbee.on()
def resetEnergyUsage() {
	sendEvent(name: "energy", value: 0.0, displayed: false)
	sendEvent(name: "energyDisplay", value: String.format("%6.3f kWh",0.0), displayed: false)
	sendEvent(name: "elapsedTimeDisplay", value: String.format("%dd %02d:%02d:%02d", 0, 0, 0, 0), displayed: false)
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	return zigbee.onOffRefresh()
def refresh() {
	sendEvent(name: "heartbeat", value: "alive", displayed:false)
	return zigbee.onOffRefresh() + zigbee.refreshData("0x0B04", "0x050B")
def configure() {
	log.debug "Configuring..."
	// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
	// enrolls with default periodic reporting until newer 5 min interval is confirmed
	sendEvent(name: "checkInterval", value: 2 * 10 * 60 + 1 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
	return zigbee.onOffConfig() + powerConfig() + refresh()
def updated() {
	response(configure())
//power config for devices with min reporting interval as 1 seconds and reporting interval if no activity as 10min (600s)
//min change in value is 01
def powerConfig() {
		"zdo bind 0x${device.deviceNetworkId} 1 ${endpointId} 0x0B04 {${device.zigbeeId}} {}", "delay 200",
		"zcl global send-me-a-report 0x0B04 0x050B 0x29 ${intervalMin ?: 5} ${intervalMax ?: 600} {05 00}",				//The send-me-a-report is custom to the attribute type for CentraLite
		"send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 500"
private getEndpointId() {
	new BigInteger(device.endpointId, 16).toString()
def getPowerDescription(descMap) {
	def powerValue = "undefined"
	if (descMap.cluster == "0B04") {
		if (descMap.attrId == "050b") {
			if(descMap.value!="ffff")
				powerValue = zigbee.convertHexToInt(descMap.value)
	else if (descMap.clusterId == "0B04") {
		if(descMap.command=="07"){
			return	[type: "update", value : "power (0B04) capability configured successfully"]
	if (powerValue != "undefined"){
		return	[type: "power", value : powerValue]
	else {
		return [:]
Hmmm, now you got me thinking about adding his stuff plus adding some stuff from my Aeon DSC06…
This is great! Thanks for posting it!
If I could make a request/suggestion? It would be nice if wattage readout was color coded. Like if it’s greater than 1, then the number be orange. And if it’s less than 1, it be blue. Similar to contact sensors color system?
But I appreciate your code, it works great for outlets connected to TVs
