I do not know anything about make edge drivers or any other software. Then I need your help and I think a lot others users too… I have leviton VRCS4-MRZ you can find DHT and SMARTAPPS in this old topic [OBSOLETE] Leviton VRCS4
Hello, I’m looking to migrate 3 motion sensor with temperature Linear (WAPIR-1) very similar or maybe the same, as the Monoprice Motion Sensor with Temperature v1 and v2 models (15271/10796).
But after erasing the old driver, un-pair and repair, all my sensors pair with the old Aeon Multipurpose Sensor.
This is the info of the device in the old IDE.
Raw Description zw:S type:2001 mfr:014F prod:2002 model:0203 ver:4.84 zwv:3.67 lib:06 cc:71,85,80,72,30,86,31,70,84
I’m in the process of migrating away from Vera & trying out an Aeotec Hub. Still considering Hubitat if I can’t get SmartThings to work.
I still use the obsolete Intermatic CA3750 for my pool pump. Vera recognizes both relays, but I only need to control one so it currently it works fine for my purposes in SmartThings as a Generic Z wave switch, but I can’t see an edge driver in the app.
Will this switch eventually lose functionality? Or will Smartthings migrate it over automatically by making a generic edge driver?
I’m sure this will work fine with the generic z-wave switch from ST although the fingerprints might not match. In that case, @Mariano_Colmenarejo has a great set of EDGE drivers and is always willing to add a new fingerprint relatively quickly to support your device. I’m sure it will work great.
I say this as ‘should’ because I have taken the CA3750 out of my system so I personally have not tried to use my CA3750 under EDGE. I bought a new VSP from Hayward with the Omni logic controller. It has Alexa integration but not currently ST. I’m planning to work on that soon using @brbeaird’s MyQ integration as a template.
Fibaro has been relying on community drivers for its fire alarm offering known as FGSD-002 running via Z-Wave+. Now SmartThings users cannot see fire alarms, smoke or temperature alerts. Fibaro claims a community developer was providing alerts for this product but now I can’t find any edge drivers for this product. If a community developer wants to step up and release a driver you will be helping to save lives in the process of pushing out an edge driver!
While you are waiting for a more expert response I will chip in my basic advice.
While the IDE is still working, click on the sensors you have paired and copy and paste the following information for future reference:
Data/networkSecurityLevel
Data/manufacturer
Data/MSR
Raw Description
These will be useful when looking for edge drivers or maybe even writing your own in the future.
I would pair as many of the sensors as you can for this purpose; you can always exclude them in fugure if you need to.
Just my thoughts.
I have a Danalock V3 which used to work great. In the Groovy IDE you could just set the type to Danalock. But since it has been migrated to to Edge, it received the type “Z-Wave Lock”. The problem is that this edge driver does not seem to recognize when the lock is open. It thinks that it is always closed. So opening via the app works but closing does not work.
Anyone with experience with the Z-Wave Lock Edge driver that can make some modifications or point me in the right direction? Much appreciated.
Thanks for the quick reply. Actually I do believe it might be the fault of the lock itself I think what’s happening is that the lock keeps forgetting its calibration settings for when its open/closed. I will keep experimenting.
It’s a nice lock but a bit flakey. Can’t wait for a solid lock that works on the Euro cylinder and supports Matter to come out.
Hi, @Zorglubxx
Once you have confirmed the issue is not the device itself, you can contact me directly or open a new post in Developer Section to report the issue.
I have a number of Z-Wave open/close contact sensors on various doors. Most of these are working and have transitioned to a corresponding Edge driver. Two of them will not find an edge driver even when excluded and included again.
Specifically, the two sensors are rebranded by Schlage so they have a different manufacturer, product and model. Otherwise, they should be identical to the Ecolink open/close sensors (DWZWAVE2.5-ECO).
Here’s the signature information for the Schlage Open/Close contact sensor. These won’t get an edge driver, even based on capability. zw:S type:2001 mfr:011F prod:0001 model:0002 ver:2.00 zwv:3.40 lib:06 cc:30,71,72,86,85,84,80,70 ccOut:20
And here’s the signature information for the Ecolink 2.5ECO Open/Close contact sensor. This do work and get a standard Z-Wave contact sensor Edge driver. zw:S type:0701 mfr:014A prod:0004 model:0002 ver:10.01 zwv:4.05 lib:06 cc:5E,86,72,73,80,71,85,59,84,30,70 ccOut:20 role:06 ff:8C07 ui:8C00
What can I do to enable an edge driver for these two contact sensors?
@philh30 & @csstup have a driver for the Ecolink 2.5ECO Open/Close contact sensor and they might be able to add the finger prints for Schlage Open/Close contact sensor to it, if it is really the same as the Ecolink.
Check with @Mariano_Colmenarejo or @philh30 they may have a drive that works with Monoprice Z-Wave Plus Door/Window Sensor (mfr:0208 prod:0201 model:0008)
Thanks, I’m checking with them now. It does seem to be equivalent to the Ecolink Open/Close contact sensor (although the 1.0 version, not the 2.0 or 2.5). They seem to support all the Ecolink versions in their driver, so hopefully it’s a simple matter to add one more fingerprint for this.
Looking for edge driver for Everspring HSM02-0 Z-Wave Door/Window Sensor
It’s fingerprint is 0060-0002-0002
I tried using the generic Z-Wave edge driver for sensors, but I don’t think it supports this fingerprint.
I was able to find a custom that supports this, but the product ID is wrong. I am not a software guy, so I don’t know how to safely modify it.
