Post Requests for LAN/WIFI Edge Drivers Here (community-created)
As JD said there is no way to directly add Tuya WiFi devices to SmartThings. You can use the official SmartLife integration but many things don’t work with it. There is a work around that gets you a 1 way integration.
Using this method you can get dimming by creating tap-to-run automations in SmartLife for say off, on, 25%, 50%, 75% and 100%. Then create a virtual dimmer in SmartThings and use automations to trigger the different dimming level you created in the tap-to-run automations. See attached for more details.
If you have questions ask
