Okay New User with SmartThings hub and so did not have Nest Dev Acct prior, but have a some Nest Products I want to add to the ST hub v3.
I have already read that I should use the ST Classic App for this Nest integration, and have downloaded and launched it successfully with the hub and I have installed the Nest Manager from GitHub and it shows up in the STC app, but says I do not have creds…
Does anyone have any detailed setup info for doing this?
I have already created Nest Dev Acct, but do not see how to create the authorizations to enter into the STC app Nest Manager…
If you want a simpler install and a resilient & reliable Nest integration (you don’t need to do the tedious process to of copying and pasting the different Nest permissions), here is an alternative:
