With the Lite, you’ll be dependent on ST. That’s probably fine. Yves’ software is good. But still. Future independence costs only $30 or so more. (If you buy more remote sensors, then it’s a little more. I bought two extra. Unless you have a very sophisticated house, you’ll probably have no need for more than 3 sensors. That’s all I have. Two would have been fine.)
You’ll also loose a lot of data on the Ecobee reports. You won’t have the follow me report. I guess that’s not a big deal. You’ll still have the general system and weather impact reports. Those are the most useful. If you want room by room reports to see how they are affecting the average, you’ll have to roll your own. That’s not so hard. It is a small minus though. . . . I’m not sure what the schedule report will look like. I think it will just indicate a long hold, as the software adjusts things using holds. Again, no big loss.
If you get the normal E3, then you have options. If you buy the lite, you have something nearly as limited as a Nest on its own. You can get a lot of power from Yves software either way. If you have the lite, you are stuck with ST + Yves to get much out of the product. That’s not so bad. But I would pay more for the option to ditch ST. I did, pay more, that is. I still have ST and use some of Yves software for changing modes. . . .
