Hey all,
I’m new here so please be nice
In Australia (where I live) we are limited to ZigBee and LAN devices dues to ST using a different ZWave frequency.
Because of this I have been trying to hunt down some in-wall ZigBee switches and so far I have only found one.
It is a glass capacitive touch in wall switch and dimmer and runs ZigBee HA and ZLL according to the box.
It is designed to connect to a Nue ZigBee hub (which I didn’t buy).
I want to get it to work with ST.
So far I have gotten it to talk and added it using the “ZLL Dimmer Bulb” handler.
However, my issue is that I can’t control the switch from ST.
I can see the status, for example when I turn the switch on and off, I see the switch turning on and off in the events and in the app.
Also when I use the dimmer, I see the level percentage change in the device events and in the app.
However, I can’t control it.
Anything I press in the app has no effect.
What am I doing wrong?
I have tried the following device handlers “ZigBee Dimmer” and “ZigBee Dimmer Power” they show the status of the dimmer but not the power on and off, but still don’t allow me to control the switch/dimmer.
Here is the catch all if that helps:
catchall: 0104 0006 0B 0B 0100 00 F781 00 00 0000 01 01 0000002000
FYI, I am not a developer so fairly new to all of this and Home Automation.
Here are some photos:
