Another firmware update, another time that I need to pull out the batteries to manually reboot my hub because it won’t reconnect on its own. Bravo guys, bravo.
I have a Samsung dryer as well, got the little USB adapter to make it “smart” and it identified as a washer as well. Sent the USB stick back.
At least it’s consistent.
Iphone x ST application crash
ANY FIXES?
I’m with you, not very “smart” in my book. It was so nice when hub and tv talked to each other.
Same here. They can’t fix it. Been that way for months.
Same crashes with that latest version.
One or another of my houses are always empty, this is why i don’t have batteries in any of my hubs. I have them on an ups with an independant wifi switch so i can reboot them remotely. It has saved my bacon a few times.
Anyone else having issues with SmartLighting functions that rely on motion sensors? I have things that worked for the better part of the past year that now are not evaluating the mode. For instance, I have some motion actions that should only run in “Night” mode but always seem to run now. It only seems to impact some sensor / light combinations and not others.
Yea same. Well at least a few that have time constraints of say sunrise to sunset -60 or such. Turning off lights it shouldnt. I doubt its because of the firmware update…but something has changed
Ha. KevinH - I just posted in your thread on the matter at the same time: SmartLighting ignoring time constraints? (Feb 1 2018)
Something has gone wrong with SmartLighting since yesterday.
A lot of problems after update. In the app on the phone (samsung s7 and iphone 6) i constantly have unexpected error or all favorites can’t lod (on every tab is the same problem). It is a mess from this morning since now, i can’t use nothing as usual… Please fix it fast because it is not sirious , just test it more … it’s shame that so many thing for a lot ot my money now are useless.
App problems aren’t related to firmware update. Look in the app threads and you will see potential work arounds to solve the app issues.
It is not app problem. On diferent devices problems are the same, and more now when i send command from the hub to ip (sonoff-tasmota) device i did not recive a response. !
First of all i am custumer and i bought a product wich can’t work without the app so it is problem for the hub and the app when somethig not working as expected… How can i get my money beck for the hub and all devices in my house…
Be more serious pleace …!
Screenshot_20180202-143837|281x500
I would suggest you contact support for serious help.
I’m seeing this too. Everything ok on iPhone, but app won’t load favourites on iPad. May have something to do with the app update released on Wednesday.
Edit: iPad ok now. Favourites showing after 5th attempt of loading.
Here exactly the same issues in the app!
It was before and after I updated the app. But after the firmware update!
So my suggestion would be that the firmware update is causing the problem.
I’m mad, I’ve lost all day trying to fix things or at least figure out where the problem is. YOu must allow the people to return a firmware version, now we can not do nothing …just wait.
I WANT TO ROLL BACK TO version 19.20
How can I do this? Since last night everything works nice…
Why not test better, why at 20.17 instead of 20.16 you have released 20.17???
@enchoss, Unfortunately there is no rollback. There’s also limited local processing, so when you’re internet has issues or ST cloud has issues, or a dog farts in another continent you may experience issues.
Lots of us have been “working through” these issues, which means just putting up with it. Generally a few days and things are back to normal. Then we go through the roller coaster again! There’s a lot of posts about stability, reliability and local processing. Just do some searching and you’ll find you’re not alone in your frustration.
