Hub and ALL Devices Gone?!?!
Mine looks like yours, says SmartThings in the upper left hand corner beyond what you grabbed with that screen shot.
what happens if you login with your samsung account using the different password?
See if you can spot this:
https://account.smartthings.com/login
Coming back to this after vacation…
So, I’ve accepted that I need to rebuild the network.
But I can’t seem to to make any existing devices reconnect to the network. New ones, no problem.
I haven’t tested extensively after having issues with the first two devices, but is there anything I should know about re-adding devices that were never previously excluded?
I am having the exact same issue. It has to be related to the new smartthings android app. It is the only thing that changed for me.
Yup. It’s absolute crap too.
The problem is that it seems to be a combination of factory reset and exclusion from the Hub and I can’t seem to figure it out. Add to that the fact that several of the devices are installed somewhere in the house and need to be brought closer to properly pair with the hub.
I’ll be perfectly honest, this has entirely turned me off from the Hub and changed it from a recommend to a do no recommend.
Customer support was useless. It’s 2018 and having no way to back up the system is BS. I’m extremely disappointed in the product and in the money that I’ve spent.
Just had the same thing happen to me. Had to do a factory reset of my phone last week, and first time I opened smartthings app it was empty except for my phone and a Samsung soundbar I have.
Anyone ever figure this out?
Update 10 minutes later - got it to work, I had the multiple hub issue in the app when I only have 1 hub… Once I switched it was fine. But have to figure out how to get rid of that…
I have the exact same problem. V2 classic hub, opened account in 2018, smart things classic app.
Things were great until this morning when all my devices and hub are missing?!?
I emailed support, so please take a look.
Go to the more menu and tap the drop down next to your hub’s name and check for another location.
OK. I’m going to take one more try on this, but have a few questions.
What’s the difference between the two apps on my phone, the new one and the old? Do I need both? Is one easier to use than the other?
Is there any way that I can nuke all old known relationships between hub and devices? I’ve been having a hell of a time getting each of them to reset.
Is there any way to back all this up yet?
This has happened to me twice now in 3 weeks. The only things that don’t disappear are my Fridge, Phone, Nest, and Rachio. All my lights, security and switches are gone. Trying to figure out what is actually wrong before I spend hours setting everything back up.
It’s unfortunate that there does not seem to be an easy way to resolve this issue. The exact same thing happened to me a few says ago: the hub and everything connected to it disappeared.
There is an easy way: check for a duplicate location in your app. Also login to https://account.smartthings.com and see how many locations you have under the locations tab
Sure, that’s the easy way to resolve it. If your problem is caused by multiple locations.
Not what caused my problem, or several other people here’s problem.
well you reset your hub, so nothing can be done when that happens.
I have had the same thing happen to me. I noticed my things were missing from the app, with the exception of my thermostat, I logged into the Smartthings site and it shows that “You don’t have any hubs yet. Please use the SmartThings mobile app to claim your hub.” And of course the App tells me that the Welcome code is already registered. WTH happened?
Go to the locations tab of the website and see how many there are
Ok I have now fallen into this issue. I only have one location and have not reset my hub. Already have called support who has been working on it for a week now with nothing fixed. Any other advice that hasn’t been offered? My devices are missing in the classic app and IDE but appear In the new app. All routines and such still run and I can control the devices in new app but Alexa does not control devices either.
What’s really weird is that in the classic app I can go under rooms and my devices are listed there and are capable of being controlled. Which is fine but any device that not has been moved into a room cannot be controlled and still no control in IDE whatsoever.
You can modify devices in the new app and assign them to rooms. That should get your missing devices into rooms on the Classic app for you to control.
Thanks for the feedback.
That’s what I’ve done for short term band aid but still doesn’t resolve the overall issue especially the not functioning with Alexa (all that matters to my wife).
