So, I’m not sure exactly when this occurred, as I’ve been trouble shooting other tech stuff in my house lately…
Only two things that I know have changed in my system - firmware update at the beginning of February and I activated Samsung Connect on my phone. FWIW, I’m on a Galaxy S8.
The other day I went to add a bulb and discovered that everything was gone - neither the Hub nor any of the devices show up anywhere (SmartThings app, Samsung Connect applet, or on the web interface). Poof. Gone.
I still have the box my Hub came in, so I re-entered the code hoping for the best and got none of my devices back. Hub shows in ST, SC and web.
I spoke to support and they had no input.
Anyone have any idea what happened? Did I nuke it when I activated Samsung Connect?
Anything to do other than rebuild it?
What the hell is Samsung Connect and should I be using it instead of the SmartThings app? Or both?
Click on locations in the menu options.
Then on home.
Does your hub now appear with your devices.
If so make a note of the rule.
This is the shard/server your hub is connected to.
interesting. did it let you re-setup the hub with the code?
tgauchat
8
What do you mean?
SmartThings Support is tremendously helpful for problems within their scope (ie, does not include developer issues or unofficial device types and SmartApps).
A customer with a “disappeared” Hub should certainly receive helpful support…
If it let you re-add the hub with the code then whatever you had previously is most likely gone. If they had that code active in the database you would have gotten an error that it was already in use.
Highlight the text you want to copy/quote. Then a greyed out text box will appear that says quote. Click on it and a box will open with the quote in it.
As per @Automated_House has said , did you put the code in again? If so, then I would agree and suggest you have reinitialised the hub and will have to start from scratch.
I wonder if you somehow have two different samsung account with the same email address and the hub setup under both. When you use https://account.smartthings.com , does it say SmartThings account or Samsung on the second screen?
