I have two THX9421R5013 At a quick glance these seem to work quite well the only issue was the
canceling of the hold and returning to following schedule seems to do
nothing.
The non working one is is a TH6320R1004.
Fails with:
Cannot get property ‘allowedModes’ on null object @ line 491
They are all conencted via redlink and working fine from the actual honeywell app.
The less optioned one seems to be failing on missing capabilities I would guess.
I believe this is because this controls your economizer correct? Based on the original post from @csuk a devices that either controls heat or cool only and not both is not available yet.
It’s a full function thermostat that controls heat and a/c for one of my zones. Only thing it doesn’t do is allow the fan to be controlled remotely from the tcc app. Not supported on that thermostat for some reason. It just isn’t an option in the app.
A few minutes ago I went on my iPhone 6s to the marketplace, keep in mind I already installed the Honeywell 9000 device type, and found it is no longer listed. So either ST pulled it or there is a major problem with the marketplace.
Thanks for bringing this to my attention, this is pretty much garbage. I just blindly updated without looking into it and I just realize that if I’m set to away mode, it changes my heat temperature but not the cooling, what’s the whole point of having both heat and cooling temp setting if it’s not going to change it. So pretty much, my AC would be blasting in the summer if I wasn’t home this whole time… FAIL by ST…
The only true benefit would be quicker status updates for the thermostat. I no longer need to wait 1 hour between updates. Previously I had to use Pollster to update the status but if I did it more than 1 hour at a time I would get blacklisted. Now it updates very quickly without any blacklisting. Can’t think of any other benefits though.
