Honeywell RTH9580WF is ready
Hey guys!
The Honeywell TCC integration is now live in the marketplace!
However, there are a couple of outstanding issues that we’re aware of and I wanted to make sure you guys are in the know.
If you’re using Auto mode, the integration will only work with the default deadband of 3 degrees F (or 2 degrees C). If you’ve configured your deadband to be different than that, please sit tight for a little bit while we get that sorted out.
If you only have a heater or only have an AC unit, the integration as it is will not work. We’ve already made a fix and I’m almost done testing it. You can expect this fix to go out next week if everything goes well!
If you use the thermostat in Celcius, make sure your SmartThings location is also set to Celcius. Likewise for Fahrenheit. We’re aware of this bug and we’re working to fix it.
Feel free to @mention me in this thread if you have any questions or discover any bugs that should be brought to our attention!
