Homeseer hsm200 no longer working
Since the last SmartThings Update this past week (July 1, 2023), i have found that my HSM200 Multi-Sensors are no longer working. Seems SmartThings has deleted the Device Driver for it and assigned it as a generic “Zwave Switch”
Can anyone help me.
RickK
The official Homeseer driver channel information is here.
  • sign up for the channel, using the link in the post above.
  • install the driver or drivers for the devices you have to your hub within that sign up process.
  • once installed, then go back to your ST app and on a device tile, use the 3 dot menu “Driver” option, then Change Driver. You should be given a list of drivers installed on your hub, which now includes the Homeseer drivers you installed earlier.
  • repeat changing for each device you need to.
EDIT: @jkp beat me to my own post
Thanks.!!!
That Worked.
My Devices are working like before.
Thanks.!!!
That Worked.
My Homeseer Devices are working like before.
Another Question: How can I find out about other Edge Drivers that maybe available ???
You can find community and manufacturer – created edge Drivers listed on the quick browse lists in the community – created wiki. :sunglasses:
They are separated by device class, so there is one list for sensors, one list for locks, etc.
FAQ: Using the quick browse lists without the community wiki
The lists will bring you back to topics in this forum, they are just intended to be a quicker way to search.
