This works fine with the stock driver, but wanting to change to reporting interval, which is currently one minute. Is anyone aware of a compatible Edge driver?
Your best bet is probably the GE/Jasco driver from @philh30 .
This is an Edge driver for GE/Jasco/Honeywell Z-Wave switches, dimmers, fans, outlets, and plug-ins, covering the range of generations from the legacy non-Plus devices to the current Z-Wave Plus devices with central scene support. Depending on the capabilities of the particular model, the driver supports:
Setting configuration parameters
Adding nodes to association groups 2 (load) and 3 (double tap)
Double/triple tap button events
Hub is automatically added to association group 3 for models that support double tap but do not support central scene
[Screenshot_20211225-124212]
The list of fingerprints currently included can be found here . If you have a model that’s not included, let me know and I’ll look into adding it.
To install:
Use the following link to enroll in the channel and i…
I tried those and - this one is Zigbee BTW) with no luck.
Since it’s Zigbee, I’d look into drivers from @Mariano_Colmenarejo .
Should have mentioned I tried his as well. I only tried one of them, but presumably the logical one.
I also tried the Zigbee generic configuration driver, with no luck.
