harobinson
(Harobinson)
January 23, 2023, 4:47pm
#1
Details:
MSR: 0063-5250-3030
manufacturer: Jasco Product
This is a plug-in module that had “Z-Wave Switch Generic” driver back in the Groovy days but has not transitioned to an Edge Driver.
Do I need to create my own custom driver or will you support this device out of box?
Raw description is:
zw:L type:1001 mfr:0063 prod:5250 model:3030 ver:3.26 zwv:3.20 lib:06 cc:25,27,75,73,86,72,77
harobinson:
Details:
MSR: 0063-5250-3030
Raw description is:
@philh30 has a driver that supports that fingerprint.
This is an Edge driver for GE/Jasco/Honeywell Z-Wave switches, dimmers, fans, outlets, and plug-ins, covering the range of generations from the legacy non-Plus devices to the current Z-Wave Plus devices with central scene support. Depending on the capabilities of the particular model, the driver supports:
Setting configuration parameters
Adding nodes to association groups 2 (load) and 3 (double tap)
Double/triple tap button events
Hub is automatically added to association group 3 for models that support double tap but do not support central scene
[Screenshot_20211225-124212]
The list of fingerprints currently included can be found here . If you have a model that’s not included, let me know and I’ll look into adding it.
To install:
Use the following link to enroll in the channel and i…
harobinson
(Harobinson)
January 23, 2023, 6:21pm
#3
I enrolled the channel in my hub. I installed the driver. But it doesn’t show up when I invoke: SmartThings edge:drivers.
How long is the delay before drivers are published to the hub?
That command displays drivers you own. You want to use edge:drivers:installed.
bep@debian10:~$ st edge:drivers:installed
# Label Name Device Id
1 SmartThings Hub SmartThings Hub 2ca01359-7f67-469e-9887-172e72b0423f
? Select a hub. 1
# Name Driver Id Version Channel Id
1 Aeotec Door Window Sensor 7 ZWA008 b874bb3e-37ae-4c96-9ea4-65ef9ac1e2e2 2022-12-02T05:33:35.530471412 2423da55-101c-4b21-af58-0903656b85ca
2 Edge Counter Utility V1 e67c842f-49a5-4083-95f0-c8137ae3c2f6 2022-09-01T17:17:05.113495102 e6e29aeb-2793-4ebf-b8f6-e37b69e32c61
3 GE Z-Wave Motion Switch/Dimmer e120daf2-8000-4a9d-93fa-653214ce70d1 2022-10-02T20:15:49.147522379 479886db-f6f5-41dd-979c-9c5f9366f070
4 GE Z-Wave Switch/Dimmer/Fan/Outlet 5ad2cc83-5503-4040-a98b-b0fc9931b9fe 2022-10-02T20:15:36.272663991 479886db-f6f5-41dd-979c-9c5f9366f070
5 Sonos LAN 2e21d47a-8f2f-4b59-972b-9ec83c466ae1 2022-10-12T19:40:46.196742133 34ee1d5a-c580-47f8-a88a-0d193b4f382d
6 Virtual Devices V2 0fd9a9a4-8863-4a83-97a7-5a288ff0f5a6 2023-01-14T18:30:26.946146113 e6e29aeb-2793-4ebf-b8f6-e37b69e32c61
7 Z-Wave Associator 038a9312-66c8-4a30-9299-b346d57f28a9 2022-09-18T14:12:33.434674562 c09d2a68-e32c-4366-a4fc-ea4731b96ec3
8 Z-Wave Device Config Mc 7ca45ba9-7cfe-4547-b752-fe41a0efb848 2023-01-03T18:29:01.596629395 c8bb99e1-04a3-426b-9d94-2d260134d624
9 Z-Wave Lock 0f206d13-508e-4342-9cbb-937e02489141 2023-01-18T18:59:22.580148645 b1373fea-da9b-434b-b674-6694ce5d08cc
10 Z-Wave Lock PH v1.00 58b24fe2-78dc-413c-bd11-ed386676ef9e 2022-09-16T15:03:07.688408966 c09d2a68-e32c-4366-a4fc-ea4731b96ec3
11 Z-Wave Sensor PH 7824e4db-9ee9-4443-8452-ddc4e4290108 2022-09-18T22:11:08.035535637 c09d2a68-e32c-4366-a4fc-ea4731b96ec3
12 Zigbee Switch f2e891c6-00cc-446c-9192-8ebda63d9898 2023-01-18T18:59:31.346506586 b1373fea-da9b-434b-b674-6694ce5d08cc
# Driver Id Name Version Package Key
1 094aa202-dc1f-47ee-bdb3-4e2bd09e83e7 Hello World 2021-10-05T23:41:45.465928 com.smartthings.helloworld
harobinson
(Harobinson)
January 23, 2023, 6:32pm
#5
Thanks for that. Getting closer. So I see the subscribed driver with the edge:drivers:installed command. But they are not available when I install a new device or try to switch the driver (has an edge driver) for an existing device. What am I missing?
Sounds like the fingerprint isn’t matching. I see it in the fingerprint.yml for the driver:
deviceLabel: GE Plug In Switch 12719
So wondering if your device isn’t reporting it correctly. Use the CLI or the API Browser+ from @TAustin to verify the device fingerprint that is registered with the hub.
I’ve had devices end up being set to all zeros that I needed to factory reset to get them working.
harobinson
(Harobinson)
January 24, 2023, 1:12am
#7
Use the API Browser and here is the fingerprint.
0063-5250-3030
The device insists on using the old groovy Smarthings-issued device handler – ie. Z-Wave Switch Generic
Here is the output from smart things cli.
henryrobinson@RobinsonFamily smartthings % smartthings edge:drivers:installed
using previously specified default hub labeled "SmartThings Hub" (00ffe28e-3b89-4222-8a64-964fb0fca545)
1 GE Z-Wave Motion Switch/Dimmer e120daf2-8000-4a9d-93fa-653214ce70d1 2022-10-02T20:15:49.147522379 479886db-f6f5-41dd-979c-9c5f9366f070
2 GE Z-Wave Switch/Dimmer/Fan/Outlet 5ad2cc83-5503-4040-a98b-b0fc9931b9fe 2022-10-02T20:15:36.272663991 479886db-f6f5-41dd-979c-9c5f9366f070
3 Z-Wave Aeotec Multisensor 267f764d-1ad5-4946-8189-9a36baad5195 2022-12-29T16:24:19.79448098 b32a790f-25c9-4bb1-a0b5-2feafa50e65d
4 Z-Wave Device Config Mc 7ca45ba9-7cfe-4547-b752-fe41a0efb848 2023-01-03T18:29:01.596629395 c8bb99e1-04a3-426b-9d94-2d260134d624
5 Z-Wave Leviton 1-Button Scene Controller f6964c6c-bf6e-4e30-ae17-0b8133dca490 2023-01-22T21:23:54.28489779 175fe0f8-d398-4fc7-b9de-2dcb69313bd9
6 Z-Wave Leviton 4-Button Scene Controller 4301547f-5a15-44e2-8f17-f147eccc9608 2023-01-21T18:00:42.866960943 721a4912-8629-4ae3-ac89-ff8e36bf03cf
7 Z-Wave Switch 2cbf55e3-dbc2-48a2-8be5-4c3ce756b692 2023-01-18T18:59:36.071657623 b1373fea-da9b-434b-b674-6694ce5d08cc
Not sure why your driver is not selected.
Henry
philh30
January 24, 2023, 1:51am
#8
harobinson:
0063-5250-3030
Apologies - looks like I didn’t push the updated driver out after accepting the pull request that added that. It will hopefully work now (once your hub gets the updated driver dated today).
harobinson
(Harobinson)
January 24, 2023, 3:28pm
#9
Thank you very much.
Getting rid of Groovy DTH’s one device at a time.
