Hi!
I’ve had a couple of issues since a power failure of which most I’ve overcome. The one big remaining issue is with some fibaro Switch 2s that I have.
I can change the state of the Switch from the app and however, changing state from the Switch itself fails.
It’s worth noting that changing state triggers a core routine, it doesn’t just toggle power on the light switch wire - my light pendants have Philip hue lamps in so the Switch is effectively running independently to achieve the result I wanted.
I know the core piston works correctly as the lamps toggle when I toggle the switch state in the app and the switch 2 relay changes state. However at the switch it does not.
Any suggestions would be greatly appreciated as I am stumped!!
