Hi Gaztea!
Where did you find that Dual Relay Adapter app ? In the Smartapp Marketplace?
Thanks,
CJ
Hi Gaztea!
Thanks,
CJ
I found none to work with Paulâs device handler.
Iâm using the 1x3kw Fibaro relay on a light switch, it works perfectly, the ONLY thing, when I use the physical switch the app icon DOESNâT register in the smartthings app, which annoying, any ideas what it could be?
If I turn the light on/off within the app, the icon registers fine.
Careful using the Fibaro relays for lighting, chaps - or any relays for that matter. They have moving parts and as such are prone to welding closed when exposed to big inrush currents like the ones that modern LEDs create. Make sure you leave plenty of headroom in the rating to accommodate.
Hi @Mark200SX
it looks like you are missing the 2 virtual on/off devices.
so you should have 3 devices listed, the physical device (with the custom code) 2 simulated on/off
and the app links all 3 together.
in the code for the device type I changed capability âSwitchâ to capability ârelaySwitchâ this is to hide it from the âswitchesâ
and the same goes for the app
if you need any more help please let me know.
Hello, can you supply a code and manual how to connect Fibaro Relay Switch 1x3kW FGS-211 to ST?
Hello @ma10
In the picture you posted this is a 3 way wiring config right ?
Where did you connect the common please? Did you just leave it on the wall switch as is?
Can I conect the common to S2?
Many thanks
Hi,
Could I ask how deep is your back box? The Fibaro documentation suggests minimum of 45mm deep boxes. I have however 35mm deep and look very similar to the above. How much of a tight fit is it?
Can anyone help out a total idiot? I have read through all these discussions, and finally managed to connect my FGS-222 and set the switched to latching. I had picked up a Z-Wave Multichannel device, with two end point switches which seemed to stop working when I published PukkaHqâs app and thought I was finally getting somewhere. Now Iâm at a complete loss with one virtual switch I somehow managed to create and the multichannel device on the My Home page. Can anybody spell out step by step what you need to publish, create and link, the FGS-222 and two separate switches in Smartthings. Iâm attempting to replace a number of X10 DIN units and I thought this looked really promising, butâŚ
Hi, @abalch, The device essentially has 2 switches, but ST can only really deal with Switch 1 unless you go into the switch on your app every time you want to turn either one on/off, so you need:
The virtual switches are what you use in other smartapps and routines etc. If you try and use the relay device in other smartapps youâll only ever be able to control âswitch 1â. So the actual device just kind of sits in the background, and the 2 simulated switches are the things you actually use to control each relay.
Hope that helps a bit?
Hi
Many thanks for the guidance. Think I may have go there now with the creation of simulated switches, just a shame that you end up with the relay device and the two switches as things on the home page in the app. Really appreciate your helpful response
Adrian
Hi Guys,
Did anyone get this to work, as a newbee I have added a device handler and published for myself but how do i associate this with a device ?
in the IDE under your devices page, find your device and click on it then choose edit.
then just select your device type handler from the type dropdown to your custome device type and hit update
Thanks for the information. I will give it a go
Hello guys!
I am really new to this and most of the stuff I read here does not make much sense to me. But I have been keen on automating my home recently. After lots of research on hubs I concluded that Smarthings is one of the best because I want it to be integrated with Amazon Alexa for voice control. I have not bought the hub yet, but I bought some Fibaro double relay switches to check the wiring and fitting in the box. I managed to wire it and fit it and with the hard button on it can only turn one relay only, is this normal? My most important question is with my very little experience will I be able to operate these switches with the Smartthings? I also have one roller shutter switch. On smartthings website it mentions it is compatible with most Fibaro switches except these 2 I have and need most. Can please someone advise and help? Thanks.
Hi. I got my electrician to install my fibaro relay today. I have powered it up and pressed the switch button 3 times but I dont seem to be able to get Smartthings to recognise it. I have attached a picture of my config (only 2 of the switches are designed to be used with the FGS-222).
Any help or tips would be greatly appreciated.
JJ
Didnt see this post, I assume you got it working in the end?
If not then I would suggest this:
Hi⌠thanks for the reply.
It seems the rapid switching (within a second) was the key. Thank you so mcuh
I have the dual relay so i guess now i need to swap the device type to control both channels (its only controlling the main one at the moment). There seems to be a few above. Any advise on which one to go for would be great.
Cheers again
JJ
Glad to hear it.
Im using âFibaro FGS-222 Dual Relayâ by Pukkahq
but Iâm actually just about to write one myself so it has child devices (I.e. separate devices which can then interface with Alexa and CoRE). Currently it is quite difficult to arrange and requires a smart app but my solution will not need it. Feel free to install as you see fit, but then perhaps give my version a go if you fancy.
Hi Guys,
I had one of these setup on homeassistant connected to a aesotec z-wave stick. That died so I decided to get a smartthings hub instead of rebuilding.
I have managed to exclude and add my aeotec multi sensor, but I cannot get the hub to see my dual relay.
Iâve tried the hold for three second reset, then press 3 times, but it never seems to work.
Anyone got any pointers, have tried this over 30 times with no joy.
I have tried exclusion too from the smartthings hub, but I donât get a notification of any kind when I do the three presses then either.
At a bit of a loss as I canât press the button any quicker?
Gareth
