Finally got the ring keypad to work with STHM back and forth, perfect. Thank you mvevitsis
BUT one thing is still not quit right. When armering from the Ring keypad the “Armed Stay” and “Armed Away” is switched around. So when I press “Armed stay” on the keypad the voice says “Home and Armed” BUT the exit delay (set for “Arm Away”) starts AND the STHM switches to “Armed Away”.
I checked everything and it looks like its setup like its shown in this forum so if anybody has an suggestion would be great. Thanks.
RBoy
219
Ring Keypad (Gen2) - Version 02.06.00
Added support for EU version of the Ring Gen 2 keypad
You may need to exclude and re-pair EU keypad for the changes to take effect. Also recommended to add a buffering repeater close to the keypad for optimal operation
Only thing that is not working is still chimes and I can hear them if I put keypad against my ear like in distance, like that volume is turned down to almost zero or something. It could be that my unit is defective but as there are others so I assume that something in device handler needs to be tunned upp regarding sound volume maybe.
Thanks again for your hard work
RBoy
222
It’s already there in the preferences page, Annoucement volume
That one is only affecting announcements and not chimes, looks like that anyway. Announcements are working as they should.
Strange thing this with chimes, signal is coming to keypad and it’s executing command but it’s barely hearable. Maybe there is something about volume they changed, I’m just speculating now , or they don’t want us in EU to use chimes 🤦:rofl:
@RBoy User from US here i am using V2 Keypad. The chimes dont seem to work i see “2:05:27 PM: info Triggering Chimes: [Security Keypad]” If i put the keypad speaker holes very close to my ears i can hear the chimes. I just brought brand new unit from bestbuy? I see @Adnan_Sarajlic reporting the same
I’m having the same trouble getting reverse Arm(Stay) state pushed to the device. I saw a bit of script and am guessing that’s a webcore screenshot, but I’ve not seen detailed directions telling you exactly what to configure, where. I don’t have webcore installed, and when I went to add it, there was a setup asking about actuators, sensors (keypad is not an option) so it’s all a bit confusing. Any help would be appreciated.
UPDATE: I installed WebCore and poked around until I found you have to add the virtual switches and keypad in, then create a web piston (didn’t know what that was) to fire off the logic shown above. After doing so I am able to setup Arm (home) from action tiles or via virtual switch and have it propagate down to the keypad and STHM.
Now I’m trying to figure out how to get the Ring Keypad to do the countdown arm sound when you begin Arm (away).
UPDATE 2: Looks like this has to be done with Intruder Alerts with Actions > create new monitor > Intruder actions > set entry delay and turn on alarms (keypad), then in Arm/Disarm under Any of these switches are on I set to the Arm(Away) virtual switch.
This is probably a very dumb question, but I’ve been trying to figure it out for a good hour now. I’ve set up a user using ULM, gave it a 4-number pin. I set up the virtual switches to arm/disarm. But when I enter the pin, followed by any of the 3 buttons, I always get an Invalid Code Detected Event.
I have tried to set up additional users with different codes, I extended the timeout duration, all this to no avail. I’m using the latest DTH (although it displays as Enhanced Z-Wave Lock, I validate its the code from the Ring keypad integration).
A bit at a loss here. Anyone have pointers on how to resolve this? Thank you!
Had some time to spare. Rereading the initial instructions, I realized I had paired using the QR code directly, so I excluded the keypad and paired it using S2 Mode. But when I did that, it never asked me to scan the QR code or enter anything - it paired as a generic Z wave device, and that’s it.
After changing its device type, it synchronized user pins. But when I enter one, it just doesn’t do anything - no event for code invalid, no event at all.
Will re-exclude tonight and start from scratch again. Any tips on the pairing part? Why did it not ask for anything once I started pairing?
Tried to exclude, wasn’t detected by Smartthings anymore. Re-added it and it works as expected now. Ghosts? Full moon? We’ll never know but thanks for reading!
RBoy
232
Ring Keypad (Gen2) - Version 02.07.00
(Fix) Ring Gen2 keypads with firmware 1.09 and above would not beep/chime
(New) Added the ability to adjust the Chime/Beep volume
Recommended to add a buffering repeater close to the keypad for optimal operation
This fails for a simple scenario, unless I’m missing something:
lets start with everything disarmed and both STHM buttons off
lets set security mode to “away” in STHM:
Because of the first screenshot the alarm will lock, that is good
But because of screenshot 6 [Auto Disarm(Away)] it will change the security mode back to disarm.
Am I missing something?
Hi. I’ve been trying to set up a “Stay” mode that synchronizes between two keypads. I’ve used Webcore to set the unused keypad to “Locked” and its mode to “ArmStay”, but this conflicts with the setting at the keypad level, which forces the selection of a mode when locked (Away by default). This means when I lock the second keypad, it triggers my “Arm Away” routines.
Sorry but no. Right from the start when you arm the system by tapping "Arm (Away)"in SHM on your phone, all conditions are met for 2 rules:
“Alert Away” which will arm the keypad which is fine
and
“Auto Disarm (Away)” which will disarm SHM and left both devices out of sync
