Hi, I’m facing the same issue after resetting my SmartThings hub.
When I try to join a channel with an invite link, only an infinite circle appears.
This issue only occurs with channels that I joined before resetting the hub.
For example, here is the channel I joined and registered before resetting the hub:
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
When I go to this link, I only see an infinite circle.
However, all of the other channels that I was never joined before are fully accessible and I am able to accept invitation and enroll.
It seems that this post is same case for me.
nayelyz did something for this case, but didn’t say what was the problem and how to solve. What should I do?
