Greetings!
I have the same problem as @Andremain. Please can you help me?
Saudações!
Eu tenho o mesmo problema que @Andremain. Por favor, você poderia me ajudar?
Greetings!
Saudações!
Hi, @Gilvandro_Souza!
So, you cannot enroll your Edge-compatible Hub in the SmartThings Beta Channel, correct?
Do you have access to a PC where you can install the SmartThings CLI?
Yes @nayelyz,
I installed the CLI on the PC, but I can’t install the driver through it either.
Even accepting the invitation:
.\smartthings edge:channels:invites:accept 6b68563b-1905-4654-8d2b-e677a2997424
Invitation 6b68563b-1905-4654-8d2b-e677a2997424 accepted.
The same does not appear in the command:
.\smartthings edge:channels:enroll
The error seems to be the same as discussed in the link:
Sim @nayelyz,
Instalei a CLI no PC, mas também não consigo instalar o driver por ela.
Mesmo aceitando o convite:
Convite 6b68563b-1905-4654-8d2b-e677a2997424 aceito.
O mesmo não aparece no comando:
O erro parece ser o mesmo discutido no link:
I’m seeing this same issue with installing Drivers from another channel. Something hosed with Driver installs in general today?
Can you share that link, please? Just to check if we see the same.
I am Andres, a member of the Developer Support team.
Can you please confirm if this same error happens for this channel? We are trying to find out if this is a one time thing or a more generic error
Check my browser for the following error messages when trying to access the channel:
Hope it helps with the analysis.
Yes it does help, thanks for sharing those captures. I already reported the issue to the Engineering team. We will keep you updated.
Great!
Here is more information about my attempts to access the channel:
2022-09-08T23:38:05.330Z Error: Request failed with status code 403: {“requestId”:“1B4AD807-02E8-4F5B-BC9D-BCDF9ABE9957”,“error”:{“message”:“unsuccessful-http-call status=403”,“details”:}}
2022-09-08T23:38:05.330Z at createError (C:/snapshot/smartthings-cli/node_modules/axios/lib/core/createError.js:16:15)
2022-09-08T23:38:05.330Z at settle (C:/snapshot/smartthings-cli/node_modules/axios/lib/core/settle.js:17:12)
2022-09-08T23:38:05.330Z at IncomingMessage.handleStreamEnd (C:/snapshot/smartthings-cli/node_modules/axios/lib/adapters/http.js:269:11)
2022-09-08T23:38:05.330Z at IncomingMessage.emit (node:events:539:35)
2022-09-08T23:38:05.330Z at IncomingMessage.emit (node:domain:475:12)
I cant enroll either, any updates on this? thanks
Wow, I certainly hope there is a better solution than this haha… thanks for your reply and solution!
