Hi @veonua,
It didnβt work as expected. Hereβs a screenshot of the device in the app: (note a Button 3 is listed)
IDE Data for the device (using the previous DTH)
CLI Logs from when it joined and a few button presses. I was able to turn on a light with Button 2, but the status never changed to On from Off. Obviously I could not try Button 1.
I manually used both buttons, which you should also be able to see in the log below:
βββββ¬βββββββββββββββββββββββββββββββββββββββ¬ββββββββββββββββββββββββββββββββββββββββ¬ββββββββββββββ¬βββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββ
β # β Driver Id β Name β Description β Version β Channel Id β Developer β Vendor Summary Information β
βββββΌβββββββββββββββββββββββββββββββββββββββΌββββββββββββββββββββββββββββββββββββββββΌββββββββββββββΌβββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββ€
β 1 β a232e466-eb39-4f8a-998b-032ea9fcd28c β Honeywell-Ademco Envisalink - Release β β 2021-11-09T20:53:29.605125 β aa65796f-d144-4860-9457-b009d88b65e0 β ea3129b7-51bc-f893-7cb5-1a79ba85f2b1 β β
β 2 β d17e16fd-bf79-42da-a22f-46cf1f8c4f12 β Virtual Devices β β 2021-10-09T22:53:35.818947 β e6e29aeb-2793-4ebf-b8f6-e37b69e32c61 β 863beb73-c3bc-6a21-10fc-0ed0a77ea3dc β β
β 3 β 054cf51f-0171-4d25-acd2-9dc739cce921 β Virtual Things Edge Driver [YG] β β 2021-11-05T09:04:33.176877 β 14bcc056-f80d-416b-9445-467b0db325e3 β 526510ce-9b38-4f6b-b144-1dc58c6393e0 β β
β 4 β b18cdef6-1d11-4a7c-a0f4-7efa554ef45b β Xiaomi Switch β β 2021-11-18T06:45:18.720853 β 609e2190-c8fa-4b9a-9986-62367890277e β 914b9e25-af9a-1d58-0ecd-d7a080c26086 β β
βββββ΄βββββββββββββββββββββββββββββββββββββββ΄ββββββββββββββββββββββββββββββββββββββββ΄ββββββββββββββ΄βββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββ
C:\st>
C:\st>smartthings edge:drivers:logcat b18cdef6-1d11-4a7c-a0f4-7efa554ef45b --hub-address=192.168.50.234
2021-11-18T22:46:29.430789892+00:00 TRACE Xiaomi Switch Received event with handler device_lifecycle
2021-11-18T22:46:29.442947517+00:00 INFO Xiaomi Switch <ZigbeeDevice: f72973f0-acdc-4075-86bc-cf4b9b92b5ce [0x92EE] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received lifecycle event: removed
2021-11-18T22:46:29.460724392+00:00 TRACE Xiaomi Switch <ZigbeeDevice: f72973f0-acdc-4075-86bc-cf4b9b92b5ce [0x92EE] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received unhandled lifecycle event: removed
2021-11-18T22:46:29.463752267+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:29.479228808+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:55.864780103+00:00 TRACE Xiaomi Switch Setup driver switch with lifecycle handlers:
DeviceLifecycleDispatcher: switch
default_handlers:
init:
added:
driverSwitched:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: switch -> Button Handler
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: switch -> Zigbee3 Aqara/Opple
default_handlers:
doConfigure:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: switch -> Old Switch Handler
default_handlers:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: switch -> WXKG?1LM
default_handlers:
child_dispatchers:
2021-11-18T22:46:55.868974270+00:00 TRACE Xiaomi Switch Setup driver switch with Capability handlers:
CapabilityCommandDispatcher: switch
default_handlers:
refresh:
refresh
switch:
off
on
child_dispatchers:
CapabilityCommandDispatcher: switch -> Button Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: switch -> Zigbee3 Aqara/Opple
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: switch -> Old Switch Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: switch -> WXKG?1LM
default_handlers:
child_dispatchers:
2021-11-18T22:46:55.875604228+00:00 TRACE Xiaomi Switch Setup driver switch with Zigbee handlers:
ZigbeeMessageDispatcher: switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: Basic, attribute: 0xFF01
ZclClusterAttributeValueHandler: cluster: 0x0012, attribute: 0x0055
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: InstantaneousDemand
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Multiplier
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
zdo:
ZdoHandler
child_dispatchers:
ZigbeeMessageDispatcher: switch -> Button Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: switch -> Zigbee3 Aqara/Opple
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: 0xFCC0, attribute: 0x0009
ZclClusterAttributeValueHandler: cluster: 0xFCC0, attribute: 0x00F7
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: switch -> Old Switch Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: switch -> WXKG?1LM
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: 0x8000
global:
cluster:
zdo:
child_dispatchers:
2021-11-18T22:46:55.941992228+00:00 WARN Xiaomi Switch Device does not support cluster 0x0012 not adding configured attribute
2021-11-18T22:46:55.945530936+00:00 WARN Xiaomi Switch Device does not support cluster 0x0012 not adding monitored attribute
2021-11-18T22:46:55.950668936+00:00 TRACE Xiaomi Switch Received event with handler _resync
2021-11-18T22:46:55.962122270+00:00 TRACE Xiaomi Switch Received event with handler environment_info
2021-11-18T22:46:55.973854686+00:00 TRACE Xiaomi Switch Found DeviceLifecycleDispatcher handler in switch
2021-11-18T22:46:55.977501020+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":2},"component_id":"main","capability_id":"button","attribute_id":"numberOfButtons"}
2021-11-18T22:46:55.995313645+00:00 INFO Xiaomi Switch Ep#1 device_id:0x0100 profile_id:0x0104 model:'lumi.switch.b2naus01' manufacturer:'LUMI' Client clusters:[Time, OTAUpgrade, ] Server clusters:[Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalMeasurement, ]
2021-11-18T22:46:56.003273561+00:00 INFO Xiaomi Switch Ep#2 device_id:0x0100 profile_id:0x0104 model:'lumi.switch.b2naus01' manufacturer:'LUMI' Client clusters:[] Server clusters:[Basic, Identify, Groups, Scenes, OnOff, ]
2021-11-18T22:46:56.006689645+00:00 INFO Xiaomi Switch Ep#242 device_id:0x0061 profile_id:0xA1E0 Client clusters:[0x0021, ] Server clusters:[]
2021-11-18T22:46:56.010503645+00:00 WARN Xiaomi Switch Did not found config for device: lumi.switch.b2naus01
2021-11-18T22:46:56.023753728+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"main","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.034917353+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"button2","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.056838103+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"button3","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.073830645+00:00 INFO Xiaomi Switch last_button_ep: 2
2021-11-18T22:46:56.081590186+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.089539353+00:00 TRACE Xiaomi Switch Received event with handler _resync
2021-11-18T22:46:56.100686145+00:00 TRACE Xiaomi Switch Received event with handler environment_info
2021-11-18T22:46:56.103892895+00:00 DEBUG Xiaomi Switch Z-Wave hub node ID environment changed.
2021-11-18T22:46:56.116425395+00:00 TRACE Xiaomi Switch Received event with handler device_lifecycle
2021-11-18T22:46:56.123370978+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received lifecycle event: added
2021-11-18T22:46:56.128234436+00:00 TRACE Xiaomi Switch Found DeviceLifecycleDispatcher handler in switch
2021-11-18T22:46:56.133472061+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":2},"component_id":"main","capability_id":"button","attribute_id":"numberOfButtons"}
2021-11-18T22:46:56.153807311+00:00 INFO Xiaomi Switch Ep#1 device_id:0x0100 profile_id:0x0104 model:'lumi.switch.b2naus01' manufacturer:'LUMI' Client clusters:[Time, OTAUpgrade, ] Server clusters:[Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalMeasurement, ]
2021-11-18T22:46:56.158918895+00:00 INFO Xiaomi Switch Ep#2 device_id:0x0100 profile_id:0x0104 model:'lumi.switch.b2naus01' manufacturer:'LUMI' Client clusters:[] Server clusters:[Basic, Identify, Groups, Scenes, OnOff, ]
2021-11-18T22:46:56.162738061+00:00 INFO Xiaomi Switch Ep#242 device_id:0x0061 profile_id:0xA1E0 Client clusters:[0x0021, ] Server clusters:[]
2021-11-18T22:46:56.166501936+00:00 WARN Xiaomi Switch Did not found config for device: lumi.switch.b2naus01
2021-11-18T22:46:56.173867686+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"main","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.186843770+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"button2","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.204141895+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"button3","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.224189561+00:00 INFO Xiaomi Switch last_button_ep: 2
2021-11-18T22:46:56.227801395+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.231211936+00:00 TRACE Xiaomi Switch Received event with handler device_lifecycle
2021-11-18T22:46:56.234435186+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received lifecycle event: doConfigure
2021-11-18T22:46:56.251883561+00:00 TRACE Xiaomi Switch Found DeviceLifecycleDispatcher handler in switch
2021-11-18T22:46:56.255873353+00:00 TRACE Xiaomi Switch Found CapabilityCommandDispatcher handler in switch
2021-11-18T22:46:56.259268311+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":2},"component_id":"main","capability_id":"button","attribute_id":"numberOfButtons"}
2021-11-18T22:46:56.286767270+00:00 INFO Xiaomi Switch Ep#1 device_id:0x0100 profile_id:0x0104 model:'lumi.switch.b2naus01' manufacturer:'LUMI' Client clusters:[Time, OTAUpgrade, ] Server clusters:[Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalMeasurement, ]
2021-11-18T22:46:56.292761686+00:00 INFO Xiaomi Switch Ep#2 device_id:0x0100 profile_id:0x0104 model:'lumi.switch.b2naus01' manufacturer:'LUMI' Client clusters:[] Server clusters:[Basic, Identify, Groups, Scenes, OnOff, ]
2021-11-18T22:46:56.296094895+00:00 INFO Xiaomi Switch Ep#242 device_id:0x0061 profile_id:0xA1E0 Client clusters:[0x0021, ] Server clusters:[]
2021-11-18T22:46:56.299900103+00:00 WARN Xiaomi Switch Did not found config for device: lumi.switch.b2naus01
2021-11-18T22:46:56.309769895+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"main","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.324125353+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"button2","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.337431936+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> emitting event: {"state":{"value":["pushed"]},"component_id":"button3","capability_id":"button","attribute_id":"supportedButtonValues"}
2021-11-18T22:46:56.353858895+00:00 INFO Xiaomi Switch last_button_ep: 2
2021-11-18T22:46:56.361162436+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C76395F, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: D052A826601D0001, dest_endpoint: 0x01 > > >
2021-11-18T22:46:56.387293603+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2021-11-18T22:46:56.404378853+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C76395F, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: D052A826601D0001, dest_endpoint: 0x01 > > >
2021-11-18T22:46:56.418100978+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2021-11-18T22:46:56.434192770+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C76395F, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A826601D0001, dest_endpoint: 0x01 > > >
2021-11-18T22:46:56.458326812+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2021-11-18T22:46:56.483701395+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x02, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C76395F, src_endpoint: 0x02, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A826601D0001, dest_endpoint: 0x01 > > >
2021-11-18T22:46:56.500292937+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xDA2E, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2021-11-18T22:46:56.513146562+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.518773103+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.535172687+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: OnOff >, lqi: 0xFF, rssi: -41, body_length: 0x0009, < ZDOMessageBody || < ZDOHeader || seqno: 0xD6 >, GenericBody: FD FF 04 01 01 19 00 00 > >
2021-11-18T22:46:56.583916437+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.587023562+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.593640395+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -40, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x2A >, < BindRequestResponse || status: 0x00 > > >
2021-11-18T22:46:56.618415187+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.629162978+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.653924687+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.659626062+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -40, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x2B >, < BindRequestResponse || status: 0x00 > > >
2021-11-18T22:46:56.676749687+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.688186937+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.699569895+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -41, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x77, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || < ConfigureReportingResponseRecord || ZclStatus: UNREPORTABLE_ATTRIBUTE, direction: 0x00, attr_id: 0x050B > > > >
2021-11-18T22:46:56.770573270+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.823624520+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.841018687+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -41, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x2C >, < BindRequestResponse || status: 0x00 > > >
2021-11-18T22:46:56.856066270+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.860588062+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.875702312+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -41, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x78, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2021-11-18T22:46:56.904147395+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.914696728+00:00 TRACE Xiaomi Switch Received event with handler device_lifecycle
2021-11-18T22:46:56.941311687+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received lifecycle event: infoChanged
2021-11-18T22:46:56.946186645+00:00 TRACE Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received unhandled lifecycle event: infoChanged
2021-11-18T22:46:56.950410937+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:56.955429395+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:56.975850728+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -41, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x79, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2021-11-18T22:46:56.995913395+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:57.003122145+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:57.012937853+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -41, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x2D >, < BindRequestResponse || status: 0x00 > > >
2021-11-18T22:46:57.037725603+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:46:57.040924937+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:46:57.051344895+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -41, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7A, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2021-11-18T22:46:57.071151270+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:47:02.262651771+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:47:02.277862979+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: PowerConfiguration >, lqi: 0xFF, rssi: -40, body_length: 0x0005, < ZDOMessageBody || < ZDOHeader || seqno: 0xD7 >, GenericBody: 00 00 00 00 > >
2021-11-18T22:47:02.292802979+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:47:03.503626979+00:00 TRACE Xiaomi Switch Received event with handler device_lifecycle
2021-11-18T22:47:03.534318146+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received lifecycle event: infoChanged
2021-11-18T22:47:03.539650937+00:00 TRACE Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received unhandled lifecycle event: infoChanged
2021-11-18T22:47:03.542807896+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:47:25.899759565+00:00 TRACE Xiaomi Switch Received event with handler zigbee health poll
2021-11-18T22:47:55.910050902+00:00 TRACE Xiaomi Switch Received event with handler zigbee health poll
2021-11-18T22:48:25.910830530+00:00 TRACE Xiaomi Switch Received event with handler zigbee health poll
2021-11-18T22:48:32.512647948+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:48:32.524332115+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -60, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0xC7, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint48, CurrentSummationDelivered: 0x000000002E84 > > > >
2021-11-18T22:48:32.554502365+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
2021-11-18T22:48:55.917772835+00:00 TRACE Xiaomi Switch Received event with handler zigbee health poll
2021-11-18T22:49:25.928867865+00:00 TRACE Xiaomi Switch Received event with handler zigbee health poll
2021-11-18T22:49:55.931746410+00:00 TRACE Xiaomi Switch Received event with handler zigbee health poll
2021-11-18T22:50:02.562279369+00:00 TRACE Xiaomi Switch Received event with handler zigbee
2021-11-18T22:50:02.568508244+00:00 INFO Xiaomi Switch <ZigbeeDevice: 075f1d68-ab6a-43b4-b19f-cde326b73f7a [0xDA2E] (WS-USC04 Wall Switch (Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA2E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8001 >, lqi: 0xFF, rssi: -58, body_length: 0x000C, < ZDOMessageBody || < ZDOHeader || seqno: 0x3A >, GenericBody: 00 5F 39 76 3C DF 8C CF 04 2E DA > >
2021-11-18T22:50:02.584858619+00:00 DEBUG Xiaomi Switch WS-USC04 Wall Switch (Neutral, Double Rocker) device thread event handled
