How to pair Aqara Wireless Remote Switch H1 Double Rocker (WRS-R02)
I had the issue where the switch just toggles all my lights after pairing and doesn’t show up in Smartthings as a device. Just want to share how I finally got it paired correctly and working.
Prerequisite: Install driver from [Edge] Driver for Aqara Switches and Remotes
  1. In app, add device
  2. Scan nearby
  3. At the switch, press and hold the right button until the blue led flashes 3 times, and release
  4. Wait until the led flashes once
  5. Press and hold until the led flashes, release, then quickly press and hold again
  6. Repeat step 5, keep holding between flashes until you either see 2 flashes or the switch showing up in the app
  7. If you see 2 flashes and the switch doesn’t show up, repeat 3 to 5
I think it took me about 20 tries to get it to show up in the app, this is the third time I re-paired and it still works. I observed that holding the button between flashes seems to extend the pairing period. Hope this will help anyone having trouble with this switch.
