Any ideas would be appreciated – in addition, while you are in there, if you see a reason why refrersh/configure trigger twice when triggered from the UI Tile
I noticed the default SmartThings handler for the Eria dimmer remote doesn’t report battery, either. It also doesn’t seem to report back to the hub at all, so it gets marked offline in the app. I’m not sure if the device doesn’t support it or if something isn’t being set right during configuration. Maybe @BroderickCarlin or one of the other Zigbee engineers knows.
no. I emailed Adurosmart support and told them. They blamed the new app UI. I informed them the battery state had never been populated by the dth, so its a problem with the DTH or firmware. They never responded after that. I suggest you contact their support to get it on their radar.
The default one when you add it to smartthings. I think it uses the standard zigbee multibutton dth.
@Automated_House I just emailed them again. I’ll update if I hear anything. They had previously (September) told me that they sent it to the development team and could not reproduce them problem.
@Patrick_van_Dongen here is a the dth sent to me directly by AduroSmart on September 22. It did not fix the battery issue and I don’t know code well enough to tell if it is different than the default dth. Maybe @Automated_House knows?
Thanks Terri.
I will try your link because I didn’t get my 4 buttons to work. Maybe this one will work for me.
Battery fix is a nice to have for me now
