Hey All,
I have the exact same issue NicolasGiraldez described. Similarly, I opened support ticket #875304 and sent some pictures as well.
If @Brad_ST, or a Staff Member who is around could kindly help me out would be awesome.
Hey All,
Hi Brad. I have the exact same issue. I got a network error first, then a message saying it was already registered. Multiple factory resets to no avail.
Can you give it another try?
Youāre the man! Working great now. Thank you!
Hi Brad, got exactly same problem others Have got and hub is not showing with ācode already registered problemā Samsung hub v2. green light on hub, done factory reset severa times, no luck. need some help please
Same problem here.
Network issue whilst doing the initial setup, now it says device already registered etc as above.
Tried a couple of factory resets but it remains the same
Thanks Brad, it worked great!
Greatly appreciated
@JamesG and @DANIELE_GIZZI can you both try again?
All working now thanks Brad.
perfect Brad! hub is up and going, excellent support! thanks from Italy
Hi Brad,
It looks like you are the expert for getting around the āClaim Code Unavailableā problem.
If you have a chance, could you please look at ticket 881954 and see if you can help?
Thanks,
Ray
Iām having the same issue while trying to re register my hub. Hoping Brad is watching.
Hi Brad, would you be able to do the same for me? Serial number is 4000311375 and I can send you the welcome code if needed
Same problem here.
@Brad_ST same issue here sn: 3010068377
Hello @Brad_ST
I have the same problem.
Today I received the 2015 smarthing hub from Amazon.
When I try to connect and enter the code it tells me that it has been previously registered and that I need authorization from the owner.
sn 4000196026
Thank
Same issue. SN 3010022427
Please contact support for assistance with this issue.
@Haidong_Xue That hub is already claimed to your account. Are you unable to reset it?
Thanks. Finally the hub works. However, when connect SmartThings with Alexa or Google Home, no device can be found.
Also, in the classic App, there is a āHomeā with no device but I cannot delete it, maybe related.
